Air Suspension Question (1 Viewer)
Oct 27, 2013
712
11,114
Portglenone, Northern Ireland.
Elddis Magnum185GT
Since July 2012
Hope there is somebody out there who can come up with a definitive answer! We have a 2013 Autotrail Apache & I want to up plate it to 3850kgs (max 2240kgs on back axle). It is 3650kgs at the moment. Been thinking about Dunlop kit with compressor, gauges, etc. installed as well. I realise I will also have to uprate the rear tyres to 112 load rating. (225/70 R15). I have just been given conflicting advice in that although the base chassis is Fiat (leaf sprung) I have Al-Ko extensions at the back for the hab compartment and it would seem it cant be done as Dunlop will no longer support the application???? Nobody else has come up with this. Does anyone have any ideas please? Taking off on hols in July with tow bar bike rack & dont want to risk grounding it on the ferry! Thanks in advance! Chris.
tonka
10,830
21,528
Cannock, Staffs
A class Burstner 800
Since 2000
I doubt an Apache has ALKO. Have you checked, easy way, see if it's steel (Fiat) or aluminium (ALKO).
Go to the SV Tech website. Fill in the enquiry form and they will soon tell you. I suspect if it's now at 3650kg then it's the standard chassis and NOT the maxi which on my 2012 Apache 700 goes to 4250kg as standard. Sometimes the cab has the maxi badge on as well, plus another thought, the Fiat weight plate will indicate its max weight.
Which Apache is it ?? May be worth mentioning that anytime you ask questions as there are several models.
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
If it has leaf springs it is a standard Fiat chassis, I suspect the AlKo extensions are rearwards of the back axle to support the overhanging section of body.
D.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Alko extension is after the axle and regular chassis so I don't see it's relevant
Have you a link to the info you are referring to?
Techno
Jul 28, 2010
15,475
20,756
May 2010
Alko is not aluminium Steve it would not be strong enough. Galvanised steel matey (y)
tonka
10,830
21,528
Cannock, Staffs
Since 2000
Whoops... always thought they were "special strong" Ali..
OK. Forget all I said...
Ninovan
Oct 27, 2013
712
11,114
Elddis Magnum185GT
Since July 2012
This was from a phone call to a reputable business this afternoon, so no link. The lady I spoke to was adamant that it could not be fitted due to the AlKo element even though, as you say, it is behind the rear spring attachment point. She said something about the system being withdrawn due to some failures? :confused: I take it the bellows fit between the chassis rail & the middle of the leaf spring directly above the axle.
Dec 11, 2011
839
2,102
Nr Hastings, East Sussex
AutoTrail Tracker RL
since 2010
Talk to SV-Tech - I have 2012 Apache 634 and did exactly what you are proposing using kit from Marcle Leisure plus 2 new rear tyres.
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
Dave Newell did ours. (y) And what a cracking job he made of it! Dunlop air bags on a Fiat leaf sprung chassis. The ALKO extensions are separate as such, and don't affect the fitting. Drop Dave a PM. (y)
Dec 11, 2011
839
2,102
since 2010
Actually @Ninovan I've just realised that I didn't go as far as you in that I didn't fit a gauge or compressor. The job is a fairly straightforward DIY one provided you're able to roll around under the van and the only 'specialist' tool I had to borrow was a torque wrench. I terminated the lines in the gas cupboard, leaving all the spare pipe curled up in case I ever feel the need to fit a gauge in the cab - but after having it for several months I don't feel the need to do so.
D
Deleted member 29692
If it's a standard AlKo I think you can go to 3850 without air suspension or buggering about with tyres.
I know we did.
Speak to SV Tech (y)
Jul 29, 2013
9,071
18,523
Salisbury
Hymer B678DL A class
since 2011
Ours is Hymer Exsis i698 4250kg Fiat Alko as above no air suspension on 16x225x75 tyres came as standard on maxi
Techno
Jul 28, 2010
15,475
20,756
May 2010
Was that Marcle liesure
Jul 29, 2013
9,071
18,523
Salisbury
since 2011
Could it be that joint plates extend along the original chassis making it difficult to fit?
Techno
Jul 28, 2010
15,475
20,756
May 2010
No
If they've been withdraw due to failures it is due to the weight and the distance behind the axle
My autocruise was fine
Techno
Jul 28, 2010
15,475
20,756
May 2010
I wonder if failures are down to user error and under inflation.
Because of a long overhang it only takes a little lift at the axle to cause a lot of lift at the extreme rear so if some users have been riding level it may cause a lot of stress on the bags.
If it has come from Marcle I would accept what they say but if anyone else I'd ask Marcle
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
I believe we were the company involved and I can only apologise for Jackie's mistake. She simply misunderstood when you said AlKo and thought you were saying it had a full AlKo chassis. In general std Fiat chassis can have air assist fitted but we have come across a couple of models where there is strengthening brackets around the chassis for rear seat belt frames and these brackets are in the way of the air bag fitment. If you would like to call us again tomorrow we can "quote you happy" (assuming no seat frame bracketry is in the way) or you could e-mail your inquiry to either "jackie" or "dave"@davenewell.co.uk with a couple of clear digital photos of the rear axle setup for final confirmation.
D.
Phillybarbour
270
216
West Lancs
Globecar Campscout Revo.
Since 2010
If SV tech have given you a solution that's what you'll need. They are the experts in this very narrow field of knowledge.
PeteH
6,853
9,030
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
Interestingly. I have seen the "official" (AIR) conversion to the "Full" Alko chassis somewhere on the "net". Which is IMV VERY expensive and involves quite substantial modification to the Rear Axle area?. If I can find the link I`ll post it.
Pete
Ninovan
Oct 27, 2013
712
11,114
Elddis Magnum185GT
Since July 2012
Looks like we're sorted(y). Have to take photos of rear suspension area for @dave newell lvs to make sure, but booked in for the job early July on the way up to Stranraer for the ferry to Belfast. (y)(y). Thanks everybody for your help & comments. MHF is unbelievable!
Dec 11, 2011
839
2,102
since 2010
@Ninovan - it will take a few tries to get the pressure right but, just for info, I find that for our Apache 634 a pressure of 1.8 bar is about right - except when we're fully loaded with wine on the return crossing!
