- Feb 22, 2011
- 9,803
- 20,219
- Hymer B544 A Class
- Since 2015
I'd posted on here previously that my air con (cab) developed a leak recently.
I had a mobile guy who came out and fixed it with a new condenser and repair to HP tube which was damaged from rubbing against radiator, and a re-gas.
All worked ok when he left.
Following week I tried it and not working, the compressor wasn't kicking in.
Fuse ok and relay tested by putting current across 85/86 and getting continuity from 30/87 with multimeter.
I put a 12v direct to the compressor and it was clicking as I think it should.
From the other side of the connector (to compressor) I tried for 12 v and found nothing when engine running and air con turned on.
Any ideas where to go from here please ?
Air con guy will come out foc for the work he did but will charge otherwise and he seems quiet expensive, so if something simple I'd like to try and fix myself.
TIA
TIA
