Adjustment of TV's, dishes etc. (1 Viewer)
US2UK
Cumbria, England
Class A
Since 2001 but new in UK
After 10 years touring North America, our Motorhome is now on it's way to UK. Lots of conversions are required, and most are being attended to on arrival. However, I have not yet found out if American TVs, dome dishes etc. are compatible to UK spec. :Eeek: Can anyone give advice ?
If the equipment can be converted, any recommendations ?
43,392
49,878
not sure about the dish but the TV wont work....the yanks use a different system to the uk.
we use PAL and the americans use NTSC
the US sat receiver may/will have the wrong transponder codes installed but could possibly be re-hashed within the menu to receive european TP's.
both TV's and receivers are cheap enough in the UK.
callumwa
4,110
4,480
Tyne & Wear, sometimes..
4 yrs +, 30+ yrs motorbike touring
Most American TV's as far as I recall are NTSC system which are not normally compatible with the European systems which are PAL. However if you are lucky it may be a "multi-system" tv, but with the US kit I would be surprised.
The actual sat dish should work, it is just a parabolic receiver, our ships dish works world wide, but you may need a different decoder and possibly LNB..
I'm sure someone will come along with more enlightening info soon....:thumb::thumb:
scotjimland
2,418
10,562
A Woosh bang
To add what has already been advised..
If it's an automatic sat dish then from what I recall from another Fun member's question on the same topic it was going to cost more to convert the software than to buy new .. I'll look for the thread ..
Personally I would ditch all the US kit .. not only is it the wrong voltage,( not a big issue as you can convert from 110v to 230v ) .. but it's also the wrong frequency .. ie 60 rather than 50hz .. it's just not worth the expense of conversion.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
My American KH dome fell into that catagory Jim
About £100 more for a new system with warranties etc than converting:Doh:
