A fly in the ointment (1 Viewer)
43,393
49,887
if you fit an 'A' frame to a newish car you are breaking the law.:Eeek: (in my interpretation of the rules)
All newish cars (But not motorhomes, yet) must conform to vehicle type approval regs.
fit a regular towbar to the back of a car and it must conform to vehicle type approval regs and MUST be fitted to mounting points built into the car at the design/production stage.
this means you cant go drilling holes in the chassis/body to mount any 'A' frame brackets and the manufacturers havent designed any such mounting points in the car which would need to be specificly strengthened and designated as mounting points.
just my opinion and sure to lead to yet ANOTHER 'A' frame debate:Doh:
scotjimland
2,427
10,588
A Woosh bang
More than a fly in the ointment, I think this a can of worms John ..
if the regs are applied to the towing bar fitted to the car for the A frame they can't conform.. as far as I know no car manufacturer provides such mounting points.
It would be interesting to see what the A frame manufactures say to that question..
Another question ..
A letter to UK Motorhomes net from the the Dept.of Transport ..
Other provisions from Regulation 15 and Regulation 86A of C&U require the fitting and use of a secondary coupling system in which the trailer is stopped automatically if the main coupling separates whilst the combination is in motion. Alternatively, in the case of trailers up to a maximum mass of 1500kg, the drawbar must be prevented from touching the ground and the trailer able to retain some residual steering.
No A frame I know has this provision, unless a Brake Buddy is fitted which has a break-away pin that operates the brakes.
Note on A-Frames and Dollies, issued by the Department for Transport
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
John have you looked into the DfT definition of a tow bar:Doh:
Mot definition is a bar contstructed and fitted to the REAR of a vehicle, any fitted items to the front are not to be concidered a tow bar IE vehicles equipt with front bars for boat launching
Jim if im reading your post right will not any braked trailer ie with beakaway cable do the same thing if a jocky wheel is also fitted it will prevent the draw bar from contacting the road and Any residule steering (whatever that is ) will be allowed to continue
residule steering read----- "out of control":RollEyes:
Information it would appear American A frames pick up on Manf Holes in the chassis:thumb:
scotjimland
2,427
10,588
A Woosh bang
:Doh::Doh: yes, I forgot about the breakaway cable. was focusing to much on the jocky wheel which I don't have .. mine has a skid plate , duuno if that counts .
Jul 29, 2007
6,554
39,784
Ipswich
RV and PVC
30 years
Hi those little Toyota Aygo cars have a screwed tow point either side up the front, that guy at the shows who fits a hydraulic brake conversion, when he does an "A" frame uses them, take the "A" frame off and un-screw the bolts and its back to standard.
Olley
Sep 27, 2007
837
289
Shropshire based
Globecar
started in 2001
Hi Jim,
Skid plates do count, problem is they greatly reduce the ground clearance space, it (I understand) should be 6" (150mm):Sad:
Without a skid on ours, it will still move forward in a break away situation, as the front lip of the coupling just slides along the road without diging in. My test carried out shortly after we purchased ours.:RollEyes:
I also understand that the vehicle construction and use regulations are currently under review, at Brussels, and when they are issued, some time between now and 2020, (my estimate) A frames will well and truely become museum pieces.:Eeek:
Nomadic
Snowbird
11,818
22,347
Liverpool.
Fifth wheel.
Since 11-05-2000
Hi John,Thank goodness my Rv is 21-2 years old and the panda is 20-1 years old.Dont think this applies to me.Having said that somone will come up with somthing,I hope.:ROFLMAO::ROFLMAO::ROFLMAO:
Snowbird
11,818
22,347
Liverpool.
Fifth wheel.
Since 11-05-2000
Another question ..
Hi Jim,Citroen Axs all had 2 towing eyes manufacturer fitted.I towed one for years on a homemade A frame for that reason.
X
Xoxoc
John I may be wrong but I think that the blue ox base plates do mount into existing fixing points on the cars they are intended to fit to.
43,393
49,887
dont know where this quote comes from but the wording is wrong.
a secondary coupling is a totally different animal to a breakaway system,.
a secondary coupling is a chain/wire rope attached to a point on the trailers/toads 'A' frame and attached to the towing vehicle.
all trailer 750kg and under MUST now be fitted with this system and can be used up to 1500kg in conjuction with a breakaway cable.
in the event of a detachment it will stop the trailer going its own way and will not apply the brakes but will retain some RESIDUAL steering.
we all know what a breakaway cable is.
but this is going away from the original thread.:Doh:
scotjimland
2,427
10,588
A Woosh bang
The Letter is signed ..
Alan Mendelson
Primary Safety Branch
if he got it wrong what hope do we have of getting it right :Doh:
sorry to drift off the topic John ... just fell across it while looking for some tow bar regulations.. won't happen again.. promise :winky:
Jim
43,393
49,887
Olley
i was thinking the same thing olley,
could be a way round it :thumb:
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
I think John in essence a breakaway cable is also a secondary coupling it is not designed to snap is it, it designed to apply the brakes and retain contact between the two vehicles, if your breakaway would snap its too thin for the job, and no its not moving of topic its one and the same surly
Must stop calling you shirly:ROFLMAO::ROFLMAO::ROFLMAO:
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
when you use an a frame you are no longer towing a car .it becomes a four wheel trailer . is there really any regs that discribe the or how we fit a hitch. i dont think so.
43,393
49,887
no alan, there isnt, but a car isnt designed to have a hitch anyway.:Doh:
Snowbird
11,818
22,347
Liverpool.
Fifth wheel.
Since 11-05-2000
Ee by gum,this is more like it.Much more interestin than lost dogs an how long batteries last.:ROFLMAO:
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
when you fit the hitch you fabricate a trailer some one designed the trailer its definately not the car manufacturer they design cars me or you can design trasilers
43,393
49,887
Mot definition is a bar contstructed and fitted to the REAR of a vehicle, any fitted items to the front are not to be concidered a tow bar :thumb:
very true Geo, but it isnt a towbar.....its a draw bar or variant of.
not teaching yer granny etc but....
a towbar has a ball or jaw and pin (unless its a NATO coupling)....
a drawbar has a cup or an eye.
anything attached to the front ie..a bull bar, winch bumper etc has to conform to CE type appoval so why is an 'A frame' mounting any different.
43,393
49,887
and another thing.......im sure iv seen the military using A frames.
are they exempt?
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
hey pappa if your bored you could polish you CARAVETTE bet that got your blood circulating.
Jul 29, 2007
6,554
39,784
Ipswich
RV and PVC
30 years
Is an a "A" framed car a trailer? if so you don't need it taxed, insured or Mot'ed, but I bet plod wouldn't agree.
Olley
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
if we look at dvla,sown wording on there a frame definition they do say it becomes a trailer and must comply with trailer rules. as for police they only report you then you go to court if c.p.s. take it up .then a precident could be set .. think about it most cover the toads number up or dont show it. if it was a car that would be an offence by itself. while doing recovery we never covered number . we in this country dont have problems making trailers from cars ie.mini vans/vw campers to make caravans. our laws are very primative really.
ourcampersbeentrashed
7,574
4,348
East London
well over 5 years
my goodness they are trying to make things complicated xxx
good luck to all funsters with toadsxxxx here is hoping a princess will soon appear xxx
