Zadi barrel lock replacement
Leicestershire, UK
Pilote
Since 2011
Bit of advice please on how to remove and replace my Vadi lock on my 2011 Pilote motorhome. I bought a new zadi barrel and removal key. Read the instructions on the net and on here. All looks straight forward. Not for me it's not.
I saw the guide published on here by Techno May 2016. He is no longer with us RIP.
The thread is
'ZADI / Vecam, lock barrel replacement guide (Rapido)'
https://www.motorhomefun.co.uk/forum/threads/zadi-vecam-lock-barrel-replacement-guide-rapido.131143/
I think I am stumbling over the spring return ie unlock by quarter turn anticlockwise but together the key out it returns to neutral position the extraction key then doesn't eject the lock as expected
Could it be my lock is secured by spring clip etc and I need to remove the handles from the door to access it.
Before I do this just wondering if anyone has advice on my setup.
My door handle is Vadi basic.
Chris
I have the same lock mech. Mine comes out fine with the red removal key but I am sure I had to hold with long nose pliers to stop it springing back. Definitely didn’t need to remove a spring clip or disassemble any of it
Does the lock removal key work even if the lock is in the locked position? If so it's a theives dream!
I need to remove a barrel from a g733, this is the same central position, lock one way unlock the other. Can I ask if anyone knows what method works if there is a circling inside or above method works etc etc…..
