I have been assisting with the refurbishment of the above MH. Finally after 6 months work we have plugged the van into to mains. The 2 x leisure batteries will require replacement however we have been able to connect a stand alone charger directly to check up on the 12v appliances. This has been a success, but the batteries don't hold a charge for long. Now when we connected 230VAC to the system expecting about 13.8v from the transformer/rectifier, probably switch mode unit I was alarmed to record 15.3v on my meter. I am familiar with BCA power supply/battery charging units fitted to many caravans and MHs but I have no idea the manufacturer of this elderly Benimar 6000ST power unit.
Another question is as the leisure batteries are in poor condition could this be a factor in the increased voltage output from the power supply unit? I first clicked the DC voltage was high before even checking with my meter was the pressure of the fresh water when a tap was opened, increased speed of the pump. When we checked the thetford loo flush, the water spun round the bowl and some spilled over the edge of the plastic bowl!! I fitted a stand alone volt meter in the DC circuit and it is sitting at 15.3v with many lights on which apart from the pump and a kitchen extraction fan, Truma heater fan are the only DC loads. Any suggestion please.
