1. NS headlamp to fit x250 ducato. Originally from a pre 'facelift' model but will fit any. Good condition, all clips intact. Replaced due to being a mismatched replacement by previous owner. There was a spider(!) in the lamp when purchased, cleaned out but some slight discolouration as can be seen. Enough rambling, 40 posted.
Untitled
2. New Countermeasured Bosch item 51908411 apparently fitted to later X250 EU5 models. Can be retrofitted to earlier models with the older sensor. Have a list of parts required. £20 posted
3. New Kavlico P604 delta pressure sensor. This matched the model number as fitted to my '12 EU5 Ducato. Unfortunately although the model matched the plug was different (includes plug if you want to chop into your loom), one pipe was a different diameter and the bolt spacing was slightly off. Otherwise identical . £20 posted
Untitled
