X250 3litre antifreeze bleed points (1 Viewer)
SandraL
1,373
985
Somerset
Hymer b694sl
About to change the antifreeze. Will order new hose clip as only way to dump seems to be pull off the lowest hose.
On refilling are there any bleed points? My previous citroen car had them, but a later suzuki didnt.
Or is it fill slowly, run engine and keep topping up.
Hoping someone has been here before....
S
SandraL
1,373
985
Somerset
Hymer b694sl
Now done. Bottom hose on radiator pulls off if you squeeze the side bits, struggle to pull and antifreeze pours over me.....
Found a bleed valve high up on bulkhead where 2 water pipes go through to heater. But so high will need some heat/pressure in system to be effective.
As on an A class filling was done with watering can, caravan drain hose on spout, domestic overflow pipe bend taped on end to fit into header tank.
