- Jul 28, 2010
- 15,475
- 20,763
- Rapido 7090F 3 litre 160
- May 2010
As promised a quick guide to replacing a long arm mirror with a medium length one.
Original view
With shorter arm
view from rear
Absolutely no need for long arms mr Rapido
First remove whatever window surround you have
remove screw then pull away at the front and lift off the rear retainer
pry out the window control panel to reveal connection
Remove the four Torx fixing screws
Feed the new electric cable through both holes and bolt mirror on
inside fish the wire through to the connection point
Reconnect and test operation before refitting trims
Difference
I will now buy a near side
Original view
With shorter arm
view from rear
Difference
