X230 Ducato - Battery dashboard light advice? (1 Viewer)
Apr 6, 2019
3,737
7,447
Eye, Peterborough, UK
RV
FourWinds Windsport 6.8L V10
Hi.
Noticed that when starting up the 2.5tdi engine the dashboard battery light stays a few minutes now colder weather is here.
Is this normal?
In the summer it stayed on around 5 or 10 seconds, blip of the throttle usually got it go out. Whilst light is on I only have 12.1 volts showing onboard (engine battery selected), as soon as it "warms up" and light goes out I get 14.4.
Should I be concerned or normal for this style/age of Ducato?
Jev88
Apr 6, 2019
3,737
7,447
RV
Could it be alternator belt slipping ?
Audibly. No. But can't rule out yet.
I do have a new tension adjustment bracket to be fitted but wondered if this behaviour is normal? Ie if alternator needs changing at same time?...... Can I check anything?
17,617
43,192
could easily be the voltage regulator on the alternator
Aug 18, 2014
23,765
133,474
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
As TheBig1 said it is the voltage regulator. My old one used to go out on its own & the voltage rise to 14+ . The new replacement you can sit there all day & ifyou don't blip the throttle it stays without charge at 12+v
Jev88
Apr 6, 2019
3,737
7,447
RV
??? Are you saying your new one is performing worse than the old one? Confused?
