Would like to play music from my iPhone via cab stereo (1 Viewer)
kitetraveller
155
45
Norfolk, UK
Citroen Relay 2 bed
Getting there!
2007 Citroen Relay with cheap aftermarket single din head unit in a double din space.
Radio does not get any decent signal, and we cannot play music from the phone as there is no bluetooth.
It plays Cd's but the sound quality is pants.....
Please can anyone recommend a head unit with bluetooth, (doesn't need anything else), and anyone have any advice about getting decent sound out of the speakers? Do we need to change the speakers? If so, is it reasonably straight forward for a numpty, or do you need special tools please?
Andy & Christine
Feb 22, 2011
9,785
20,150
Newcastle under Lyme
Hymer B544 A Class
Since 2015
I have a JVC single din with bluetooth and that works fine.
I think really it`s one of those things where you get what you pay for, if you pay £45 it`s unlikely to give a good tone or have much power.
At 10 years old the speakers will probably be past their best and are usually easy to replace and worth the effort.
I`d go down to Halfords or in car entertainment specialist and have a listen to different ones.
Lenny HB
53,417
149,915
On the coast in West Sussex
Hymer B678 DL
Any of the branded stereo's should be reasonable sound quality. JVC are OK at the cheap end if you want something a bit better there are plenty of options, Kenwood, Pioneer, Clarion etc.
Don't be surprised if the Bluetooth won't talk to an iPhone but all stereos should have an aux input you can just plug a lead into from the headphone socket on the iPhone and the better ones will have a dedicated USB/iPhone port.
Speakers are very easy to change, if they are in the door you will have to take the inner panel off. If in the door worth putting some sound deadening foam on the door behind them.
9,385
24,754
Derbyshire
Elddis Accordo 105
since 2014
I changed the speakers in the car and stuck sound deadening sheets on the door skin. It sounds loads better now. It's worth buying the tool to get the door cards off, that makes it so much easier..
Look at this on eBay http://www.ebay.co.uk/itm/252532421563
This stuff enhances the bass.
138go
3,276
14,613
Carthago 138
Since 2001
I don't think it will be double din. The Fiat version certainly isn't and you need a kit to change it. You also need a Dremil to cut away some of the dash. Once this has been done you can then fit a double din cage.
Some of the Fiat / Citroen radios look like double din but they are single with a deeper front. Very much a design aimed at making sure you only buy their radio.
7,248
11,731
West Sussex
Carthago Compactline
Since 2003
You should get better sound quality from an iphone using the lightning port rather than the headphone socket or bluetooth. If you want a wire free solution airplay is better than bluetooth but not many radios support this. Some hifi enthusiasts would advise that when looking for quality of sound start at the source and work through the sytem doing the speakers last, if the source is poor the speakers won't cure it.
9,385
24,754
Derbyshire
Elddis Accordo 105
since 2014
I disagree, and I was told at college that speakers are the weak link and most of your budget should be spent on them.
Theonlysue
6,104
7,383
Essex
As Executive 50th an
Not long enough!
Can you connect earphone socket on phone to I put on radio with lead? Mini jack to mini jack
Silver-Fox
9,265
29,071
Cheltenham Spa
Rapido
im a not so newbie
If you don't want to change the radio you can buy a cheap item that tunes into a certain radio frequency and plugs into your i pod
7,248
11,731
West Sussex
Since 2003
Fair enough, opinions on this seem to differ. It was something I read on a hifi site but perhaps it does not help Kitetraveller solve the connection problem.
kitetraveller
kitetraveller
155
45
Norfolk, UK
Citroen Relay 2 bed
Getting there!
Many thanks for all the useful replies!!
I took the head unit out, and discovered an Alpine AI-net connection on the back; I had to look it up, had no idea what it was, but found an Alpine lead that plugs into this, and has a 3.5mm jack and lightning plug so I can get music and charge my iPhone at the same time.
There is also a lead with just the 3.5mm jack for audio; at £6 I ordered one to try.
I will let you know how I get on.
Thanks again all.
Andy
