- Jan 11, 2018
- 1,235
- 1,470
- Chausson Welcome 85
- Since 2018
A little help please if you can..........
I am about to buy a Rewire Tracker for my motorhome
This device has the facility/option to have remote imobilisation.(£15 extra)
In order to do this the +ve supply to the starter motor pre-engage solenoid is interrupted by fitting a standard 5 pin automotive relay.
The supply is wired through the normally closed pin of the relay (pins 30 and 87a)
When an 'imobilise' signal is received by the unit and it's GPS sensed speed drops to zero or a minimum , the relay is activated and the stater motor supply is interrupted. (relay actually switches to connect pin 30 to pin 87 (to which nothing is connected) thus then going open on pin 87a)
All fine so far.
Therefore I need to find the cable supplying the +ve feed somewhere highish inside the engine compartmentof up inside the dash/fasia so I can fit the relay.
The unit will be behind the radio, so the starter motor cable needs to be split and brough up to this area.
Could any Funsters help with how to locate this cable , please?
2008 Ducato (X250)
I know the starter motor end should be easy to find but it's further inside the beast I need to go, possibly picking it up from the ign switch or one of the fuseboxes?
Thank you
DB1 Advanced
DB1 GPS Tracker offers everything that you want from a GPS vehicle tracking system at a reasonable price for locating cars, order online.
www.rewiresecurity.co.uk
All fine so far.
2008 Ducato (X250)
Thank you
