Wireless alarms - any issues? (1 Viewer)
HumBea
12
8
Portsmouth, UK
looking
Hi. We're getting a motorhome next year, and are currently spending our waiting time investigating motorhome security. The nearest alarm/tracker fitter to us seems to use the Autowatch 695 system, which I believe uses wireless sensors on the habitation/garage doors. My question is, how "safe" are wireless systems? I believe a jammer can be bought off ebay for pittance: are alarms clever enough to recognise when they are being jammed and go off anyway?
Apologies if this is a daft question - I'm reading/watching lots about security at the moment, but finding the electronics side of it a bit confusing!
Sep 17, 2017
4,966
8,788
Birmingham, UK
A-Class
We've got wireless sensors in the house alarm. They are reliable. Although they do lag a few seconds compared to the wired ones. They are also annoying to have to change the expensive batteries every couple of years.
For a van, it's not normally that hard to route wires. Van Bitz alarmed several doors on ours.
Silver-Fox
9,034
26,790
Cheltenham Spa
Rapido
im a not so newbie
How would anyone know your van alam was wireless. We have had Autowatch alarms on all our vans they work well.
I’m not talking about blocking the sensors just a tracker.
I prefer hard wiring sensors either at home or the Moho.
Better reliability imho.
62
107
Essex
Bailey AA79-4T
Since 2019
Recently talked to a foreman at motorhome insurance approved repairer. He explained that every stolen motorhome that they receive has been trashed inside, panels broken, etc. as the SCUM were looking for a tracker. His advice was don’t buy a tracker! but use the money to prevent the SCUM taking your motorhome in the first place. Cab deadlocks, hab door lock system, steering wheel lock, wheel clamp, disk lock for drivers seat, etc. etc.
If ours gets stolen we don’t want it back. Thanks.
Upvote 1
Lenny HB
50,266
138,787
On the coast in West Sussex
Hymer B678 DL
Most insurance companies will only insure if a tracker is fitter on vans over 75k some companies insist on them even on lower value vans, so you have no choice.
62
107
Essex
Bailey AA79-4T
Since 2019
Our moho 22 plate over £75k, LV= insure the moho, no problems.
eddie
8,008
39,280
Taunton Somerset
RV
since 1989
Wireless sensors in a motorhome are useless, not Thatcham approved and can be rendered useless by a thief from outside the vehicle
#chocolate teapot
Going further I 100% guarantee I can render them inoperative without touching the vehicle
H
HumBea
12
8
Portsmouth, UK
looking
Agree that it's better to keep them out of the van in the first place. We're looking at the physical deterrents too - they are a lot easier to understand than the electronic stuff!
H
HumBea
12
8
Portsmouth, UK
looking
#chocolate teapot
Ah, interesting that you say wireless ones aren't Thatcham approved. My local fitter's website says their alarms are Thatcham 1 approved, but their videos definitely say wireless sensors. Hmmm! Glad I've got 5 months to investigate all this properly before we get the van! Thanks for your feedback, I expect we'll be giving you guys a ring when we've done a bit more investigating!
9,035
23,581
Derbyshire
Elddis Accordo 105
since 2014
Our autowatch is Thatcham approved and has a wireless proximity sensor on the ceiling. The door sensors are all wired Reed switches though šŸ‘
eddie
8,008
39,280
Taunton Somerset
RV
since 1989
I've got a Thatcham certificate with mine, the insurance wanted to see a copy.
It's only the ceiling sensor that's wireless though šŸ¤”
Maybe it's level 4 or something 🤷
Thatcham will allow ā€˜additional’ sensors to be used, but doors should be hard wired.
Irrespective of that, just think about it? Hard wired means no batteries to go flat, or to change, wireless sensors can be jammed ridiculously easily, if a sensor is off line the system probably doesn’t even know leaving you vulnerable, a properly installed, wired Normally Closed circuit tests itself every single time you arm the system and alerts you if you’ve left something open of there is a fault, which has to be better.
Modern WiFi cameras, like Ring have two way communication between the camera and a hub so you can be alerted to low battery or a unit being offline, the hub being wired which you talk to via an App, the aftermarket alarm sensors are simple not that sophisticated, they simply work or not, and in the main the only way of knowing is to walk around setting the alarm off to test them!
If your alarm installer is running cables to the rear of the Motorhome for rear LED warning lights and to facilitate an accessory protection circuit to alarm bikes on a rack and or a trailer, then ensure the doors and lockers are properly protected.
Just think how useless and unreliable wireless reversing cameras are? Wired anything is still better, which is why a wired internet connection is better, safer and faster.
Wireless sensors are convenient for the fitter, as it dumbs down, and speeds up the installation.
I don’t really have an axe to grind as I’m semi retired and will be retired from Christmas but I started a motorhome alarm company nearly 33 years ago, have been invited to and been involved with Thatcham, and before that I personally wrote the code of practice for fitting alarms to Leisure vehicles for the V.S.I.B (Vehicle Security Installation Board) and when push came to shove I broke into a locked alarmed motorhome and hot wired it in twenty seconds for a magazine called MMM
So I have a little knowledge šŸ˜‰
Clive Mott
Nov 12, 2012
244
386
New Milton
Concorde Charisma
Since 1972
If your moho is going to be parked up without a hookup or a good array of solar panels then be very aware that all these security systems put more drain on the battery and can lead to a flat starter battery after a month or two. Ask the question, What is its standby current draw. Take. Clive
DT
Dec 27, 2020
357
1,012
Shropshire
Burstner 690G
Boats Caravans & Motorhomes for 25 years
I have the Autowatch system that my dealer arranged. 27 months later works fine no issues.
Two on Tour
9,748
45,648
Elddis Autoquest 175
Since 2010
The Autowatch 695RLC system that's fitted to our van for the past 9 years is hardwired to the bonnet, cab and hab doors with a wireless PIR senor in the hab area.
I bought and installed 4 additional wireless sensors to the external locker doors.
The system certainly works as it goes off when I forget to disarm it from time to time.
The only problems I have had over the year has been a corroded bonnet switch which I replaced with a stainless steel version and the hab door contact that played up and I replaced.
No problem with our insurers as the Autowatch 695RLC system is on the insurers database of Thatcham approved alarm systems for motorhomes.
eddie
8,008
39,280
Taunton Somerset
RV
since 1989
And there’s no reason you should, it’s correctly hard wired for the cab doors the habitation boor and the bonnet, thus meeting the fitment policy
The other thing that makes systems’Non Compliant’ Thatcham wise is when the alarm is plugged it on the OBDP Taking a Thatcham approved alarm out of approval for incorrect fitment policy
10
21
Adria Izola
I know it's extremely helpful for people asking questions and if you are doing research, but telling the whole world exactly what security features you have on your own van does seem slightly foolish to me. You never know what low-lifes might find this information useful.
Two on Tour
9,748
45,648
Since 2010
And just how would a would-be thief match a Funster on the forum to a specific motorhome that they are intending to steal?
More over, if they could identify that specific motorhome, then they are more likely to avoid it as they know that will be more hassle than it's worth and move on to another MH.
Minxy
31,959
63,570
E Yorks
Carthago Compactline
I understand your way of thinking but it's very, very unlikely that any 'scroat' would bother to come on this forum, search for suitable 'targets' and then be able to find those specific MHs and even if they could they'd be pretty stupid to go for one with security stuff instead of ones without.
