extra 5psi is probably something to do with mitigating flat spots on the rubber. A flat tyre has more surface area = bigger flat spot? I mark the tyres/wheel at the contact point, take it for a spin then hopefully I am sitting on a different bit of rubber when I park up; works well for meReally like the winterisation info provided it's very handy as a checklist (just moved all my cereal, biscuits etc out of the van!)
Just wanted to ask why I should put an extra 5psi in my tyres?
Always fit mine when not using the van stops all the crap getting in.And another question please...
I've always been puzzled about the vent covers for my 'fridge. Do I put them on (in the winter) just for when the van is not being used and then take them off either in the spring or when I want to use the 'fridge even in winter? Or should I put them on in the winter and leave them on, even if I'm using the van?
Remove fridge vent covers if using the van and the ambient outside temperature is more than 10°C. The covers impede airflow when conditions are warmer and your fridge won’t work efficiently.And another question please...
