windows required in van conversion
Rob Bob
Mercedes sprinter
How many windows are required when converting mwb sprinter van?
If memory serves it need a minimum of two in one side not counting the cab door window.
Side sliding door counts as one.
Motor caravan external permanent features
This list describes the external features which are commonly seen in motor caravans, and it is intended to provide guidance on what DVLA expects to see when considering your application:
  • 2 or more windows on at least one side of the main body (this does not include windows on the driver or passenger doors) to provide a reasonable amount of daylight into the living accommodation
  • a separate door which provides access to the living accommodation of the vehicle (this excludes the driver and passenger doors); a window on this door counts as a separate window on the main body
  • motor caravan-style graphics on both sides of the vehicle
  • an awning bar attached to either side of the vehicle
  • a high-top roof (this does not include a pop-top elevating roof)
DVLA will need photographic evidence of the completed conversion.
Minimum of 2 windows (excluding cab) but can be on different sides if you wish.
Even if you have the full list don't get your hopes too high that you will get "motorcaravan" in the V5 :)
Forget the DVLA requirements you will be very lucky to it reregistered.
just decide how light you want the inside if the van to be and where you are going to fit cupboards seats etc.
