DAVWOD
High winds on Wednesday afternoon has lifted the sat dish and for some reason (despite switching the unit on) won't go down into the parked position. Can any MHFunsters recommend someone to help me out on this...MANY THANKS
Chances are it has simply moved on the spindle.
You have to get up there, release the bolts ( one on each end of the spindle and let it go down to the rest position
Once down, retighten the bolts and it's a done job
The reason it will not go down any further is because the end of travel inhibitor switch is already activated so the gubbins thinks the dish is already right down
Sounds like what happened to mine. I did the same loosened bolts turned unit to off, set dish in parked position tightened bolts again and all was well
On our hymer very close to the electroblock is another fuse. This feeds the satellite. On our van it is only 200mm away from electroblock. Hope this helps. Edit, power still comes via electroblock and not direct from the battery.
Cheers I did a thorough search no more fuses in that area I'm kinda guessing its behind a panel where the Sat receiver and monitor is ... I think I need to park it by releasing it first ...
Thanks for all the replys I have had , unable to sort it out myself having seen the base of the Sat Dish was a one piece unit
a Local Mobile Caravan (Telford) and motorhome service Technician
has removed and reset the Dish then replaced a blown Fuse ...
So is it fixed and working now ?
If you had good service can you name and praise technician ?
Is your MH in storage, looks a respectable clean place, and can see some units even parked undercover..!!
