Halifax lithium battery house fire footage prompts warning https://www.bbc.co.uk/news/uk-england-leeds-64881631
They are all lithium ion batteries. There are different chemical compounds inside them. Most types have a compound that releases oxygen when heated. If there's a fire, this contributes its own oxygen to the fire, so smothering it to prevent oxygen reaching it doesn't work. Lithium Iron Phosphate (LiFePO4) batteries don't release oxygen when heated, so they don't cause a self-sustaining fire. That is the type used in motorhomes.This will be a lithium ion battery.
It says a Motorbike, not many people charge a motorbike inside their houses.This will be a lithium ion battery. Any idea what from? Laptop? Drone? EBike?
You are correct. They are all lithium ion.They are all lithium ion batteries. There are different chemical compounds inside them. Most types have a compound that releases oxygen when heated. If there's a fire, this contributes its own oxygen to the fire, so smothering it to prevent oxygen reaching it doesn't work. Lithium Iron Phosphate (LiFePO4) batteries don't release oxygen when heated, so they don't cause a self-sustaining fire. That is the type used in motorhomes.
The energy density of LiFePO4 batteries is not as good as other lithium ion types, so you have to balance size/weight/convenience and safety. Many batteries for house installation are LiFePO4, but many are not, including the Tesla ones.
Here here.... someone with a sensible head on their shouldersIf I gave you a list of causes of fires in the household that I was required to submit to the Home Office on a regular basis whilst serving in the Fire Service you would up sticks and move into an open field and live in a Tent...but make sure the tent was man made fibres, with wooden poles, pitched on low ground away from any overhead cabling, underground pipework conveying flammable substances and not prone to lightning strikes. See you there... I'm in the next field...
It's a combination of batteries being pushed too hard (because you can put a cheaper battery in for the same performance by ignoring safety margins), cheap batteries not having safety features and cheap chargers having poor detection logic.Isn't the main problem the battery chargers and batteries are not matched?
I bought two batteries with our bicycle conversions that came with chargers in the box, keep an eye on them, they are air cooled and nothing gets hot.
Yes, but don't let facts get in the way of a good whinge.So far all the bad quotes on this thread are for "Lithium Ion" battery's...
Not "LifePO4".... Totally differant beasts..
All Lithium batteries are Lithium ion batteries, including LiFePO4. The movement of ions is what makes all batteries work, even lead acid batteries move ions about. In Lithium batteries it is Lithium ions that are moved. What makes LiFePO4 a totally different (safer) beast is what the Lithium is combined with. Lithium combined with Iron Phosphate is much safer than Lithium combined with Manganese Oxide or Cobalt Oxide.So far all the bad quotes on this thread are for "Lithium Ion" battery's...
