Will a bicycle with hydraulic disc brakes leak if I store it upside down (1 Viewer)
Jun 10, 2010
8,607
20,452
Shrewsbury (sometimes)
N&B Clou Liner MAN
I've got a few too many bicycles at the moment and looking at ways of storing them in the garage at home. I've got quite a bit of redunadant space above the motorbikes and saw this nifty trick of screwing a couple of tool hooks in the roof joists and hanging the bike from the wheel rims upside down. I think this would work better for me than the hoist things because it gets them tighter to the ceiling. But I'm wondering if it will affect the hydraulic brakes?
Apr 19, 2019
2,295
4,862
Carado T339
5 years
It's a good question. My view is that it wont. Or at least it shouldn't.
icantremember
8,351
17,588
Near to Watton in Norfolk
Hymer T-SL668
since 2005
I have a Mioura Tower which stores four bikes in a small area .....
Jan 30, 2020
3,007
14,952
Mid Bedfordshire
RS Endeavour
Just a tad..
won’t leak, or rather shouldn’t leak as it’s a sealed reservoir.. what you will probably achieve is pushing any air in the system to your callipers, so expect a ‘long pedal’!
Sep 10, 2017
427
964
They wont leak, I store the bikes that aren't used all the time in the rafters of my garage and pull them up on a rope and pulley.
They are attached with a loop around the saddle and another over the bars.
Bikes are a right pain to store, 9 in my garage!
Jim
Ringleader
Jul 19, 2007
36,652
132,529
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Shouldn't affect the brakes, or suspension if you have it. But if you have sprung forks, many/most of those use oil for dampening in one of the legs. This oil is thin and upside down will leak if your seals are not 100%.
Sep 10, 2017
427
964
That's a fair point and great excuse to up grade and get air forks ;)
kevenh
3,319
11,801
Thatcham
Compass C-Class
I'm a Progressing Newbie
Late to the discussion but a cycle’s hydraulic brakes are a sealed system yy
Oil in suspension parts though, hmm!
Right, I think I’ve recovered previous replies 🤪
Air v oil suspension - it might be a performance upgrade but I’ve found maintenance costs of air suspension higher.
Are there top spec MTB suspension forks using cheap to maintain springs or oil? 🤔
Nov 18, 2011
11,865
43,697
Planet Earth
A van
Over 25 year's
Bikes are ment to be wheels down any hydrolics are designed to be stored and operates the right way up gravity is a strange thing only person that actually knew about it has passed away
Thers a opportunity for a study.
Of the effects of gravity on push bike braking systems when hung upside down for long periods of time.
Bill
Apr 22, 2018
6,849
12,628
Herts.
Adria Coral lowline
Won’t be a problem for brakes or suspension. They are both sealed systems.
You’d soon know if the suspension wasn’t as it wouldn’t work for long, and you will notice that people/manufactures mount rear shocks either way up.
funflair
19,520
31,085
Guisborough
MORELO palace
since 2012
That looks a good solution for my Hydraulics one, Not sure if there's enough in the budget for the string though :LOL:
You know I like a bargain Jon ;)
And interestingly (or not) I have just shortened a hydraulic pipe on the Pino and even though the master cylinder open end was pointing down when I took the pipe out I have not needed to bleed it.
Apr 30, 2020
442
6,355
Hartpury, Gloucester, Gloucestershire, UK
Bailey Autograph 796
Not a problem with modern bikes and air shock / fork technology. I store mine upside down and the answer is no leaks.
Just takes a little while for all oil to drain back through any suspension dampers when you turn it back right side up that’s all. On modern bikes with air shocks even having weeping seals in use is not a problem because even the longest travel forks typically hold <15ml of oil and under use the fork grease typically resides at the top of the stroke acting as an additional static barrier. Rear shock stroke is typically <50% of the fork and with a proportional reduction in oil volume.
Actually storage upside down is a good way of identifying if your brakes need bleeding. If the bite point changes as a result of the bike being the wrong way up - even for as little as 10 minutes - then brakes need bleeding.
Nov 4, 2011
6,002
40,171
Uk
Nov 14, 2018
1,102
2,577
Europe
A grey one
since 1996
Will a bicycle with hydraulic disc brakes leak if I store it upside down​
Sounds like the title of a song by The Smiths.
Sorry to be flippant!
jongood
Jun 10, 2010
8,607
20,452
N&B Clou Liner MAN
