sean n maggie
have got a 3 modem that works great in UK,,but will it workin france ? if not what do you all use please ?:Sad:
Do you really mean wifi, or do you mean mifi? If the 3 modem works on the 3 network then the answer is yes it will work, but it will cost you a fortune in data charges.
what is best to use ??? it works through 3 network and we just use for lap top....:Sad:
A EuropaSim - 3 Euros per day for 500Gb per day. And you only pay on the days you use it. Can be used all over Europe. www.motorhomewifi.com. Be quick, they only have a few left
Huawei E5332 Unlocked Mobile Wi-Fi Modem from amazon and a Mobi-data sim which give Europe and world coverage see Broken Link Removed
Seems to work very well and can connect up to 8-10 devices, as the modem acts as a hotspot, so really great for laptop , kindle etc
Not sure I have got this right, but it seems that they charge 15p per Mb when you are abroad. Is that correct? If so it could turn out very expensive.Huawei E5332 Unlocked Mobile Wi-Fi Modem from amazon and a Mobi-data sim which give Europe and world coverage see Broken Link Removed
Just got my europasim. It's working fine, in fact I'm using it now, even though I'm at home. The signal is only 1bar but the speed is good.
Quite chuffed with my purchase. I only bought the sim as I already have an unlocked Huawei E5332.
Don't forget you can manually change mobile networks with the EuropaSIM. Simply turn off automatic connection (and make sure the E5332 is in a disconnected state) and then enable Manual Network selection. You can then connect to any network not listed as 'forbidden'. :thumb:
I have set mine up as per your instructions provided with the SIM, ie manual connection and APN set to mobile.vodafone.it.
I assume it will automatically use the strongest signal, so please what is the advantage of manually selecting the provider?
Also do they allow tethering on their SIMs please.
Great news, but no doubt we'll be stung in some other way by the providers. :Sad:On 3 April 2014, MEPs voted by 534 votes to 25, to end roaming fees within the European Union from 15 December 2015.
