My VB semi air suspension arrived today. So up with the van, onto axles stands & wheel chocks.
Started to knock off the rubber bump stops and the first one started off easy then got tight, so I give it a spray of releasing fluid (not WD40). Left it a while then went back to it, still quite stiff but it was going round and slowly lowering.
Then it happened.....it dropped slightly (20mm approx) but won't come off, it's swinging on the bolt which is now just turning. I can get my fingers onto the threaded nut it screws onto, and that's solid but for some reason the bump stop just turns around and wont drop off.
Any ideas ?
I'm going to try the other side see if that will drop off which may give me a clue to what is happening.
Any ideas ?
