As has been stated on other threads, they are as noisy i they are not fitted well.How noisy are they, was parked next to a Vito campervan in Mevagissey and that seemed very noisy, I was considering removing gas fire and adding a diesel heater now not sure
There is a quiet pump available via a guy in Colchester apparently
I fitted a chinese diesel heater to our classic type 2 and very happy with the results.Subseque tly fitted an all in one to the garage.On the van used 2 silencers and now hardly audible.Fuel pump also not really noticeable but at front of vehicle but still only thin steel between us and it. Make sure you get the right depth turret to suit the overall thickness of your floor build up.Plenty of choice on ebay and install tips on Youtube
Tried and tested Chinese Diesel heaters
Buying a Chinese Diesel heater can be a bit of a minefield if you have never purchased one before, there are so many different manufacturers, suppliers and designs it can be hard to know where to start. UPDATE - WE HAVE POSTED A NEWER UPDATED VERSION OF THIS POST FOR 2022/2023 PLEASE CHECK IT...www.vanlifeuksurvivorsguide.co.uk
Noted but lot of what I said might still be of useYou may have missed in the thread title that the OP was asking about mounting under their van not inside their van.
What is your base vehicle?I'm thinking of installing one under the motorhome, plenty of room, so any advice or tips are more than welcome, rhanks
They need silencers fitted on both the exhaust and ideally on the air inlet side as well. Some installers don't fit them, either to save a bit of money or because doesn't understand the need.How noisy are they, was parked next to a Vito campervan in Mevagissey and that seemed very noisy, I was considering removing gas fire and adding a diesel heater now not sure
We have an Adria 670 SLT - on a Fiat Ducato baseWhat is your base vehicle?
I've fitted four to VW T5 & T6s, not all in the OEM position but all underneath.
Sorry in yhat case I can't be of much help to you.We have an Adria 670 SLT - on a Fiat Ducato base
