juliandavies
Hi mate,thats not a bad failure,stick with them,instead of looking round for another.
The bad lights sound like earthing problems do as suggested,if changing the flexi brake hose, do all, as they are pretty cheap (under a tenner) and the system will only need bleeding the once,so saving money and dodgy brakes,loose flexi,clip back in or cable tie.
Emmisions......diesel or petrol ? first new air filter and clean housing out,secondly if deisel maybe check or renew fuel filter,and add a fuel additive for combating high emmisions ? dont go to a dealer,go to a corner shop/factors.....and not Halfords,expensive.
As suggested,beast it,on the way to the MOT station,get it hot,go down the motorway or dual and blast the cobwebs out ! then as quick as you can,without parking up for ages,straight into MOT,usually they will give you a time to take it in,if it still fails on emmisions,let them tweak it,if they do...
To be honest,you have to spend a little money on upkeep of your home or pride and joy,if done regulary,then it will last and go through many MOT's,when you have time ,paint all underneath with metal paint (cheap if its industrial for factories)better i reckon than that glop,called underseal.
Fog light if working (on wrong side) buy for around a fiver,bolt on otherside to an earth/body,run wires back to otherside original/connect...take out original bulb.
sadly they dont do repairs
It is petrol (7.4 V8). Had sparks, oil filter, air filter changed at start of 2009 (4000 miles since then)
see new post for the quote I've got||!
