Which towbar for Fiat Ducato based Moho? (1 Viewer)
Jun 2, 2018
448
1,010
Beautiful North Wales border
Carado T449
Since 2015
We've recently bought a 2018 Carado T449 which has a Ducato base.
I want to DIY fit a towbar, possibly with a rear beam as I may make a vertical kayak rack for it.
How do I identify which towbar I need without taking it somewhere?
I've fitted towbars to a variety of vehicles in the past, and it is a simple case of entering model or reg number into a website. Bit harder for the MoHo it seems.
I know the dimensions of the chassis at the back, and apparently it is widetrack.
Robin
Sep 26, 2013
4,169
5,154
Market Rasen
Self Build
Since 2003
It will depend upon which chassis it is, is it a full Fiat one or Fiat plus Alko extension or even a full Alko one.
4,169
5,154
Market Rasen
Self Build
Since 2003
Have a look underneath, if it’s lightweight construction for the last metre or so then it will be an Alko extended Fiat chassis. If it all looks a bit lightweight then it will be a full Alko. You should be able to tell if it’s a full Fiat one by it’s more solid construction.
raysalaugh
2,254
4,171
Leyland
AT Delaware
since 2010
Hi,
You could try Mick Parkinson at motorhometowbarslancashire.co.uk he is based at Freckleton. Lanc's
Ray
4,169
5,154
Market Rasen
Self Build
Since 2003
Just had a look and that van is 7.43m long so will not be on a full Fiat chassis so either full Alko or Alko extension.
43,323
49,440
If its painted its Fiat, if its galvanised its Alko.
The front, under the cab, is ALWAYS Fiat.
From there back it can be either (full) or both. (fiat main & Alko rear extension)
8,632
44,545
Worcestershire
Bailey Adamo 75-4t
March 2018
I have just had a towbar fitted to a Fiat Ducato 7.47m and it's a beast!
Lots of chassis extention bars, spacers into the existing chassis to stop them collapsing etc etc.
Cost £1200 fitted, I would not want to do it myself.
23,773
133,572
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Robin
just remember that post 2012 have to be homologated and you cannot alter/modify them unless it was originally homologated with them.
I.e you cannot fit a drop plate/riser unless the bar was tested originally & homologated to use one.
Lenny HB
53,420
149,939
On the coast in West Sussex
Hymer B678 DL
Won't be an Al-Ko extension on a Fiat chassis it will be made by Corado/Hymer and only be there to support the garage. A towbar will have to be mounted on the main chassis. Don't forget a towbar weights at least 50 kg so will loose that from your payload and probably over 60 kg from the rear axle loading.
43,323
49,440
There's a lot of things in this world you aren't supposed to do.
