- Jan 11, 2018
- 1,164
- 1,348
- Chausson Welcome 85
- Since 2018
My MH has a Varta G3 battery in the leisure position.
When charging I see 14.4 volts , so my charging system is working.
However, when rested and the charger is off I see 11volts, even after 12 hrs charging.
So it's goosed, and since it is a cranking battery not a deep cycle battery, perhaps no suprise.
I've identified 2 batteries I have in mind to replace it.
Specs are identical, except one is NCC class A and the other is not classified by the NCC.
One is £109.13 and the other £143.98
What does the Forum think?
I know the NCC scheme has it's critic's , is the expensive battery worth the extra?
Is the expensive battery any different?
Can't compare weights.
No specs for number of cycles at a particular DoD etc.
I note the cheaper battery is warranted for 4 years the expensive one for 2 years, although battery guarantees are practically worthless if you read the exclusions.
It's not that I can't afford the more expensive one , i want to seek the Forum's expertise.
And how come the expensive one has much more charged for delivery?
Thank you
EXV110 Enduroline Calcium Leisure Battery 12V
EXV110 Enduroline WET Lead Acid Calcium Leisure Battery <i>Enduring Power for Every Cycle</i> The Enduroline brand name is the flagship battery of Tayna Batteries. With the highest quality, power and performance. With much care and attention to detail lavished on every model. We are extremely...
www.tayna.co.uk
ET650 Exide Marine Leisure Equipment Battery 12V 100Ah
ET650 Exide Marine & Leisure Equipment Battery Exide are one of the leading battery companies in the world and have been delivering quality in the sector for more than 130 years! Exide has introduced its next generation of car/light vehicle batteries. The range is developed in Exide’s original...
www.tayna.co.uk
Thank you
