We are looking to replace our leisure battery. We've had a Banner 115/135ah, for the last 3 or 4 years, which Is no longer holding charge. Any recommendations?
What’s the problem with AGM Batteries?Exide Gel as @funflair suggested, but only if your charger supports Gels. Steer well clear of AGM batteries IMO.
They look good, 30kg for a 95ah@20hr rate and confident enough to give a decent warranty.Don't know what age your MH is. Some of the newer MH support Gel batteries but you have to switch it to Gel on the battery charger controller. On Older MH it may be necessary to change the controller which starts to work out more expensive.
If your charging system supports Gel I would go for something like these. https://www.alpha-batteries.co.uk/12v-110ah-leoch-powabloc-tubular-gel-battery/
I fitted one in our previous MH and I have recently fitted two in our newer MH. Gel batteries charge at a slightly lower rate that Acid batteries, but GEL can be discharged down to 20% where as Acid batteries can only be discharged down to 50-60% depending on the quality. Plus these GEL batteries are guaranteed 6 years. They have worked fine for me.
In the real world users don't rate them.What’s the problem with AGM Batteries?
They don't seem to last half as long as GEL's. Ask @Jim our leader.
Everything, totally unsuitable as a leisure battery, often don't last much longer than a year yet they are more expensive than gels which last 6-10 years plus.What’s the problem with AGM Batteries?
I asked the question as my new van came with a Varta AGM 85ah Battery and I wondered why manufacturers fit them if they are not up to it?Everything totally unsuitable as a leisure battery, often don't last much longer than a year yet they are more expensive than gels which last 6-10 years plus.
Probably because the buy them at the right price.I asked the question as my new van came with a Varta AGM 85ah Battery and I wondered why manufacturers fit them if they are not up to it?
But if you go back 5 years wasn't he singing the praises of AGM stop/start car batteries.Well worth reading, his knowledge comes highly recommended
http://www.aandncaravanservices.co.uk/battery-technology.php
Malcolm
Martin
I have read the link many times actually, including originally when they were praising AGM but just because technology changes it doesn't mean it is better, after reading their comments and others I decided to ignore them and stick with good old tried and tested GEL.Go back a few more and somebody was singing the praises of the steam engine. their comments at the time were probably based on all available information at the time. Battery technology changes, as you'd know if you bothered reading the link and they change their recommendations as required , which to my mind is all to the good.
Malcolm
Martin
i like the idea of being able to use most of its capacity instead of only half of it , they are much lighter and when you have nowt left , with the correct b2b charger let the engine tickover for an hour or so and you get loads of charge back ,like you said , just the costIf you don't use hook up and are planning to keep van.... go lithium.. yes expensive but well worth it IMO.
Ideal Charge Voltage | 14.1v - 14.4v |
Top Up Charge Voltage | 13.3v-13.8v |
