Hi All,
My 3 year old Banner batteries have gone belly up.
Recommendations on best ones to buy please.
I wouldn't want to be lifting that.Thanks for your thoughts everyone,was thinking about 1 at 230 a/h rather than 2 at 100.
At nearly £300 a pop I would expect about 10 years usage..Will a gel battery last twice the number of years as a wet battery ? As they seem to be about twice the price.
Only 40 - 50% dearer, but Varta LDF90 approx £100, Sonnenschein 78 a/h approx £ 140 the Varta will give 45 a/h useable power where as the Gel will give 62 a/h. Taking into account those figures they are roughly the same price.Will a gel battery last twice the number of years as a wet battery ? As they seem to be about twice the price.
I'm not sure if Autotrails have a Gel setting on there charger but if they do a couple of Sonnenschein 78 a/h gels would be better value around £140 each from Tayna.
Gel charge at the same voltage as flooded cells but they need a long absorption time 4 hours min preferably 8 hour plus to reach a full charge. On Flooded setting they will only charge to 80%.Doesn't mention Gels so suggest OP (@Floridalil ) seeks guidance from Sargent (https://sargentltd.co.uk/). In addition, they recommend a maximum capacity of 120Ah \ battery.
You're letting the side down here.I removed 2 Banner AGM batteries that wern't really giving enough power as we do more off grid living up in the Highlands.
I read through Lennys posts re batteries and went for Exide Marine 85ah GEL batteries, biggest we could fit in the space provided. I wasn't really worried about cost.
The batteries are topped up with 250w solar panels via Schaudt MPPT regulator. They very rarely drop below 13v even after an evening with LED internal lights, heating and an hour of DVD. If we get 9 or 10 years from these batteries I'll be well chuffed.
https://www.alpha-batteries.co.uk/12v-110ah-leoch-powabloc-tubular-gel-battery/Will a gel battery last twice the number of years as a wet battery ? As they seem to be about twice the price.
They look goodhttps://www.alpha-batteries.co.uk/12v-110ah-leoch-powabloc-tubular-gel-battery/
The above batteries are guaranteed for 6 years. I had one on my previous MH which I sold. I recently fitted two on my new to me MH.
No they are not they are about 40% dearer but produce about 40% more available power. I wouldn't use anything else.Gels are still double the price. I think if you don't discharge your batteries and keep them topped up, a standard good quality lead acid is the way to go.
They last years on cars because the charging system keeps them topped up. Each to their own though, no offence![]()
We are all LED lighting takes about 6 amps providing we don't turn them all on, TV, 2.5A, head unit (for TV sound) 2A, sat receiver or Android box 0.5A, laptop, tablets & phones about another 6 A.I suppose we're light users with LED lighting, a small TV and water pump. I can see the gel benefits![]()
