That’s a good point. I’ve just switched ours over from the EBL99 to the Victron charger inverter. I think it’s default factory is Gel but I need to checkFor optimum charging and battery life, AGM and gel batteries need a special charging profile that provides an extended timed 'absorption' stage. The settings for AGM and gel are very similar, but not exactly the same. It's quite likely there are switches to set the charging profile. If you have an Electroblock 12V distribution fusebox, it may have some small switches on the front panel. Do you have an Electroblock (EBL) and if so what model number is it?
The EBL built-in mains charger is usually 18A, which is fine for an 80Ah battery.
The solar charger is I presume 110W, not 110A. It might have switches or a menu option to change the battery charging profile. What make/model is it?
