Which amp hookup (1 Viewer)
Jan 28, 2016
2,396
2,767
Stockport, Cheshire
Bravaria i740 AClass
We have a choice of 6amp 10 amp or 16amp on our pitch in south of france this august
How do you know which you require as bigger amp more cost
We would have following on electric
Led lights turbo vent water pump hairdryer occasionally?
DBK
17,912
47,666
Plympton, Devon
PVC, Murvi Morocco
You're hairdryer will dictate the amps. All the rest will run off 6 amps. You can get travel ones under 1200W which you could probably use with 6 amps too. :)
Sep 26, 2013
4,016
4,776
Market Rasen
Self Build
Since 2003
Are your lights and water pump not 12v, you may have a battery charger to run as well unless you have solar.
Riverbankannie
10,123
58,657
Bristol
IH 630 RL PVC
As ever @DBK has hit the nail on the head. You will be able to run everything off 6amps except a typical hairdryer of 1600 watts which will take 7amp on its own.
It’s worth buying a low wattage dryer for MH use.
Jul 29, 2013
8,866
16,134
Salisbury
Hymer B678DL A class
since 2011
If you go for low amps remember if you use the hair dryer and kettle together or any big amp electrical you’ll trip the feed.(y)(y)
Sep 26, 2013
4,016
4,776
Market Rasen
Self Build
Since 2003
If they are offering you a choice it could be a site where they stick the appropriate fuse into the box and lock it up, you may have to then find someone to reset it for you.
Jul 29, 2013
8,866
16,134
Salisbury
since 2011
Also worth remembering if you have the hot water heater on in the van whilst on hook up as that will use quite a bit of power when running.(y)
Jul 29, 2013
8,866
16,134
Salisbury
since 2011
Yes and that’s a pain as well and some put an extra charge if you trip more than two or three times.(y)
42,963
47,024
Only way to know is add up all the 230v appliance wattages.
Don't forget your fridge and chargers input wattage.
Up to 1380 watts you will need 6amp
Up to 2300 watts you need 10 amps
Up to 3680 watts you need 16 amps
You can always turn off one or more appliances to run another one though on a lower amperage hookup.
Something like a fast boil house kettle will be 3000 watts and you may need to turn everything else off to be sure not to trip.
two
Aug 4, 2011
4,805
4,414
West Midlands
A-Class Fiat
At 6A, you'll need to be careful if you do any heating (water/kettle/toaster/hob/curlers/drier/...)
Even low wattage devices might trip the supply if used together.
6A is fine for general operation of the motorhome (fridge/charging batteries/lights/...)
Feb 22, 2016
3,355
9,803
York
Bailey 620 Approach
Since 2015
Not wishing to in anyway hijack the thread, do appliances like a motorhome fridge, water pump, tv have their wattage marked on them? If they are designed to be used on hookup then they would be 230v. If you know the available ampage, then you can easily find the wattage. But what if you don't know the ampage? Sorry if I'm being thick.....
two
Aug 4, 2011
4,805
4,414
West Midlands
A-Class Fiat
Yes, they do specify wattages, but don't confuse 12V with 230V and remember that most will not be consuming whatever they require all the time.
When on 6A mains, you may need to juggle what you're using to ensure that only one "heavy" item is used at a time.
Most Europeans survive quite happily on 6A EHU.
It's us Brits that have been used to 16A over here (and have acquired a plethora of devices to make the most of it) who may trip up (or off).
Jul 29, 2007
6,467
37,893
Ipswich
RV and PVC
30 years
How long are you staying for?
Riverbankannie
10,123
58,657
Bristol
IH 630 RL PVC
If you're staying at a campsite why not consider using the shower block power sockets for the hair dryer.
This is what I do. I have purchased a hair dryer and a hot air brush, in supermarkets, for the princely sums of 9 € (spain) and 16€ (Germany) respectively. Having euro plugs already fitted makes it so much easier in the campsite shower sockets.
Mikey RV
4,545
22,238
Devon
Burstner Elegance I821G
Since 1977
We are on 10 amp and have the heating on bit if we put the electric kettle on to boil we have to turn heating off. Same with Nikki s hairdryer, one on one off. (y)
Oct 13, 2016
1,027
897
Grays - Essex - UK
Mercedes Hymer B680
Been moho’ing for a time now
tonka
10,670
21,019
Cannock, Staffs
A class Burstner 800
Since 2000
I can only quote on what is fitted in my 2012 Autotrail but Electric water heaters in some Truma units are not actually that big. 800w seems to be average. So while a reasonable amount not over the top like those daft hair dryers. ! ;) :D
Janiemou
133
72
Scotland
Coach Built
4 years
We stay on campsites all over Europe - it's always the microwave that's the critical factor.
Dec 16, 2017
1,187
2,385
Almuñécar, Spain
Low Profile - Globebus T7
We often use a plug in portable fan heater when on hook up to save our gas. It's got settings, 1500 and 3000 w so even on the 1500 setting itl still draw 6.5 amps so a 6 amp supply doesn't work for us. IMO you'd be better off going for the 10 A option at least. Or, if they're happy to upgrade it, start at 6 and suck it and see..
Oct 13, 2016
1,027
897
Grays - Essex - UK
Mercedes Hymer B680
I think you've made a mistake somewhere, as that would be 1,934 a year for a 6amp supply which is ridiculous !!
Just check it out !, generally we pay about 4.50 / 5.00 per night here in the UK, so what makes the Euros any different ?, we pitch up quite regular, and it’s generally €5.00 pro nacht, absolutely ridiculus, but fact is fact
Aug 18, 2011
11,867
17,109
derbys
AUTOSLEEPER SYMBOL
I always send the better half to the shower block to dry her hair,,tripped too many leccy posts over the years to risk it now,,BUSBY.
