Hymerbell
- Apr 2, 2014
- 1,112
- 2,583
- Hymer 674
- Since 2002 plus 20 years in a tent
£299....wonder if it’s cheaper if I have already got the MiFi
I fitted a USB socket near the MiFi so battery life isn't an issue. The MotorhomeWiFi aerial is good and their after sales service excellent but the Poynting MIMO 1-1 is what several of us on here have fitted. It is a complex subject as the frequencies the suppliers use vary as you can see here.Yes think I am going to have to go with MotorhomeWiFi 4g Aerial...last one went to meet its maker...managed to keep the MiFi as had it on me. It’s a E5577C....must say the battery life is rubbish though...
Complex ?......Nah....I thought the Azimuth 1700-2100 radiation pattern was the prettiest but of course you couldn’t get Love Island ? on that so will probably plump for the 2000-2300 Mhz standing wave ratio one.....anyway is it a lot better than the Motorhome WiFi one and how much does it cost and did you fit it yourself ?I fitted a USB socket near the MiFi so battery life isn't an issue. The MotorhomeWiFi aerial is good and their after sales service excellent but the Poynting MIMO 1-1 is what several of us on here have fitted. It is a complex subject as the frequencies the suppliers use vary as you can see here.
4G and 5G frequency bands in the UK
Each network uses a different bands and they also differ based on the type of network (2G, 3G and 4G). Check the frequencies all UK networks use in one place.www.4g.co.uk
The 800MHz band is used in some rural areas as it will travel a further distance but the data rate is lower than the higher frequencies.
The Poynting antenna has different performances for different frequencies but it covers the 800MHz band and the higher ones which covers most bases. It isn't so good at the mid-range frequencies but I don't know how commonly these are used. If you want to look at alternatives see if you can find any published data on performance as opposed to the broad brush "+6 dB" or whatever they claim which will only be true for a narrow frequency band and it may be much worse on others.
The Poynting data can be seen here:
I bought mine from Solwise and it is worth looking at their website. It has some useful technical advice too.
I don't know if it's better or worse than the competition as at the time I bought it a couple of years ago Poynting was the only manufacturer who published performance data, which was why I chose them. What I do know is I'm very happy with the performance as are others who have bought one on here.Complex ?......Nah....I thought the Azimuth 1700-2100 radiation pattern was the prettiest but of course you couldn’t get Love Island ? on that so will probably plump for the 2000-2300 Mhz standing wave ratio one.....anyway is it a lot better than the Motorhome WiFi one and how much does it cost and did you fit it yourself ?
Cheers
Alex
100 gb on Vodaphone,,20 pound a month.Crikey I’m now onto MiFi data Simms....in my previous MH I had a Huwaiwhai MiFi and a 4g roof antenna. Put a 50gb data Simm in for £30 a month and it was fine although made sure I wasn’t streaming HD. I have now got to sort out another one, still have the MiFi but the aerial went to meet its maker (long story).
Now I have discovered that Vodafone don’t do that particular Simm anymore and have switched to unlimited for £37 a month....HOWEVER for roaming its capped at 20GB. Is there a way of getting true 50GB plus data whilst roaming ?
You will still get a good idea if the aerial is working as it will probably will double your upload speed compared to no aerial.I fitted it but can't test it as where i am located the signal strength is already good.
AFAIK there's no way to stick an aerial etc into your (or any?) phone to improve the internet signal.I use my Samsung Galaxy A3 to connect my tv laptop etc to the internet..How can i improve the signal strength,,Thanks in anticipation.BUSBY
Coming into this half way through.
The Poynting 1-1 is end of life.
There are some versions with the wifi in addition still about.
It has been replaced by a 3-1 which is physically much higher although a similar footprint.
Im not qualified to say which if any is better than another but Poynting were adamant the new one would be better than their previous version.
And its not badly priced.
