zac
That looks similar to the one i posted earlier or similar design but the thread is a lot shorter by the looks of the specs.Check with the supplier if the antenna you want requires a ground plane. If it does mounted on a pole it may not work optimally and of course it would be very vulnerable to branches.
I fitted a Poynting MIMO-1-01, bought from Solwise and wrote a thread about it on here. I chose it over the one you are looking at because they publish all the test results about it. Have a look at the tech specs link in this page (below). However, I don't know if it would go through a thick insulated roof. You would have to check on the length of the mounting bolt.
I'm sure the Motorhome WiFi one works very well but I'm very happy with the performance of the Poynting one. There's even a bit about my installation on their Case Studies page. (I didn't write it by the way!)
