Where to buy Solar (2 Viewers)
jako999
304
785
Halesowen
Niesmann Bischoff
Hi all
Looking at getting a couple of new solar panels for our new van. I bought the ones for thelast couple of vans from Photonic Univers and they have been very good and a decent company to deal with but I’ve found a company called Sunshine Solar and they look the same panels but at a cheaper price, both say they are German cells and both have 5m of cable. Has anyone bought from this company and where else have people bought from?
Aug 9, 2019
151
163
Bessacarr E442
Or britain
Ive got these on my house but sadly couldnt fit them on mh because of previous bracketry.
looks good but bet they are pricey
8,475
20,120
Shrewsbury (sometimes)
N&B Clou Liner MAN
Most things not produced in China are pricey but happily are generally better quality.
The unseen element of all these short term savings is CCPs true intentions, as we have seen only last week they have ambitions in other places the more powerful they grow the more difficult they will be to tackle. Have a look at debt trap diplomacy
Steve-N
160
237
Cheltenham, UK
Fiat Ducato Camper
2nd Campervan since 2019
A 180W panel output is in optimum conditions. Stuck on your van roof they won't put that much out unless you visit the Sahara in June. 2x 180W will be fine with that MPPT.
Infrared (heat) has little to do with solar output, their output is linear to light (ultrviolet) so Iceland or north Norway would be just as good as central Africa
8,475
20,120
N&B Clou Liner MAN
I think the reference is to overhead uninterrupted sun.
3,579
7,737
Amersham
van conversion
Since 2019
The heat does impede production, not as much as low light, but anything above 25degC will start to diminish. A panel is tested at 25degC with a light intensity of 1000w/m2. These are called STC and printed on the label. Now you could have a situation where solar irradiation is more than 1000w/m2, even south Spain receives 1200-1300w/m2 in some places. But you have heat to. The de rating is listed in panel data as temperature coefficient. The smaller this coefficient, the less loss due to heat. If you have a panel without this info, it’s not very professional panel. Near Equator you have the sun above, but shorter day. You may have a peak power but going north or south, you gain time in daylight. You will not have the peak but more time to harvest longer in summer.
27
38
McLouis Steel
20 years
Hi all
I have used 2 flexibles on the boat.... they fit along the boom so a bit of curvature helps. One had an intermittent fault and it has been replaced without any problems. I just had to send photos of doing a couple of tests with the multimeter. So pretty happy.
I think mine were German Chinese as well. Difficult to buy panels not of Chinese origin. Bit like lithium car batteries, most are made in China.
27
38
McLouis Steel
20 years
Sorry forgot to add these were from Sunshine Solar
1,949
2,272
Suffolk
2017 Chausson 718XLB 180
20 years
Hi all
If Sunshine solar are in Norfolk that's where I got mine from they were just the job
