- Jul 28, 2010
- 15,475
- 20,756
- Rapido 7090F 3 litre 160
- May 2010
yes
I believe there is a subtle difference between the cak tanks version and the van blitz. I thought the cak version would only charge the vehicle battery when if there was a charging current supplied to the leisure battery. The van blitz would transfer between a fully charged leisure battery and the vehicle battery, without mains charging taking place. I chose the cak unit on price as I have solar panels and hence a charger and it's worked brilliantly. Three wires only and a completely sealed unit. It only takes a few minutes but fit and to play safe I fitted fuses on each end.Phoned CAK and they are out of stock (again?) of their Battery Charge Master BCM 12 (was CBE CSB-2), new stock due on or around the 27 January.
As we are leaving the MH for up to 3 weeks soon wanted to fit this before we went. There is a working solar panel fitted to the MH leisure battery.
So the question is, is it possible to buy this in it's original guise as a CBE CSB2 product either in the UK or Germany/France?
Similar product to vanbitz unit
Link Removed
I know this doesn't answer the original question. [HI]A temporary fix whilst waiting for delivery would be to connect both batteries together with FUSED leads.[/HI] When starting the engine just remove the fuse, but if you forget you just get a blown fuse.
Check with Hilldweller first because I'm dumb when it comes to circuits.
Brian.
I think that before rushing out and buying electrical gadgets, reading and understanding the function of your present system could save a few quid.:thumb:
Our last two MHs have both been fitted with CBE electrical distribution panels and both charge the cab battery when the leisure battery is charged above a certain voltage. A solar connection is also integrated into the panel.
Obviously, if your MH hasn't got this function then buy away, but I just want to make people slow down and think before rushing out and buying unnecessary kit just because they read it here!
