When is an ambulance not , dvla (1 Viewer)
Feb 16, 2013
19,734
52,021
uttoxeter
ambulance conversion
50 years
heres a conundrum for you, not mine but my sons , he got the log book through for his ambulance he's converting and still says ambulance on it , he's gone to tax it on line and it came up as free as it's an ambulance , so obviously he did it , but what's he do now , he's got it insured as a conversion being done but now is it legal on the road or not, or what do you change the log book to , ambulance, van, motorhome or what or just leave it as it is and tax it for free.(n)(n)
43,329
49,443
Motorhome.......after the conversion.
It won't get changed before its completed.
Taxing as an ambulance when its No longer in official service is fraud.....so it's not taxed.
DVLA now require pics of the inside and outside to prove it actually looks like a motorhome.
A van with side Windows is not enough and things like decals and an awning will make all the difference to their decision.
A pic including the reg plates and VIN plate wouldn't go amiss as well.
Then it needs a bed (can be converted from seating) a water supply, a cupboard, other specifics I can't remember.
Insurers generally put a time limit on the conversion before it has to be completed.
23,782
133,614
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
If the dvla won't change a 'van' ,that is taxed as a 'van', to 'motorhome' until it is converted to there satisfaction then they have no defence to an 'ambulance' that is no longer an 'ambulance' remaining taxed , foc, as an 'ambulance' until such time as they consider it converted there satisfaction.
They cannot have it both ways.
Nov 18, 2011
11,862
43,010
Planet Earth
A van
Over 25 year's
Take a pick of bead and a porta potty cooker and any thing motorhome related to show them it is a motor camper
i have Don three in my time a telephone conversation with them and a designated email address of the person you talk to so you can send pictures directly to them
have you got any pick you can put up on this thread might help to advise you better
bill
Emmit
8,034
17,752
Pilote Explorateur
Jan.2014
If your son wishes to continue using the 'Vehicle' I would suggest that he changes it's Taxation status to PLG (or, if the weight is more than 3500Kgs to Private heavy goods) He should then, when he has converted it to being a motor caravan, he goes through the process as described above.
Oct 2, 2008
4,471
7,956
Salopia
Duro 6x6 Overlander
since 1968
If it does not technically comply with requirements with being a motorhome then it is just a van , so plg is taxation class.
It ceased to be an ambulance when it was not operated as such by a
qualified authority . Its the same as fire engine in private hands it cant be tax free because you are not a fire authority . I have had both as preservation vehicles. :) Carmicheal TACR2A
Oct 1, 2007
7,064
13,964
Kirby cross further from londin
Between Motor homes
since 08
get it registered as a panel van
that is what i had to do with
my old patient transport ambulance
when its converted fully reapply for motor caravan
this link may help explain your needs for reregistering as a camper/motor home
https://www.caravanwise.co.uk/motor-quote/diy-camper-van.html
43,329
49,443
qualified authority
But it's still registered as an ambulance, which is tax exempt, regardless of it being in private hands or not and the taxation can't be changed until the body type/design has been changed.
DVLA will only tax it in the class it's registered as.
Jul 12, 2013
3,872
5,274
The City of Henlow
Adria Supreme
Since 1980
I believe that if gas is used, it will require a certificate of safety. I am guessing that until it becomes a 'Motorhome' it will be classed as a van and require taxing as such.
Whether SVTech should be involved with any new weight restrictions after being kitted out as an MH I am not sure but still worth considering.
Insuring it may also involve some interesting discussion.
Oct 2, 2008
4,471
7,956
Salopia
Duro 6x6 Overlander
since 1968
An ambulance is a van with a bed or stretcher in it , If you think that by buying an ambulance and then loading it with parcels you wont get nicked for using it tax exempt then feel free to try :)
All you need to do is tell DVLA thats its now a van , its different with the second change to motorcaravan as you need to show compliance with what is defined as a motorcaravan
A motorhome could be an ambulance @pappajohn
D
Deleted member 29692
A friend of mine has a work van that was previously owned and used by the Fire Service so is exempt from everything in the same way as an ambulance.
He's had it for about 3 years and in that time hasn't been able to tax or MOT it because the DVLA say it's exempt and point blank refuse to change the class.
He's got copies of all the correspondence and has given up arguing with them.
Oct 2, 2008
4,471
7,956
Salopia
Duro 6x6 Overlander
since 1968
He must be doing something wrong these guys are doing it all the time
https://www.forcevans.co.uk/
I have no connection financially or otherwise with this firm , other re sellers of ex emergency services and ex gov vehicles are available (y)
jonandshell
5,476
8,299
Not got one!
View attachment 205939 If it does not technically comply with requirements with being a motorhome then it is just a van , so plg is taxation class.
If you ever want to shift it, I have an RAF Fire Section to put it in!
11,932
9,078
We went over all this a few weeks back on a thread :DI have done 3 ambulances and a bus and quite a few vans this is what I had to do
if being used on the road you will have to reg it as a PLG /ie no longer used as a ambulance so either van or minibus and taxed /ins as such
To comply with MH conversion which will be registered as Motor Caravan
It already has windows in so complies with first bit ,looking like a mh
then must contain as already stated in posts above ..seats/convert to bed ...sink ..cupboard/wardrobe ..2 ring cooker and a table
take photos as a van showing number plate if poss then as a converted MH again showing plate if poss. send v5 with change of use to Motor Caravan(y)
32,649
66,541
Fill in the V5C to change it to a van then he can tax it and legally leave it on the road (assuming it's not off the road at the moment), he can then use it if he wants to whilst converting it ... make sure he's aware of the time limit that his insurers have stipulated for the conversion to be done by as they can be quite strict. He also need to check exactly what is needed for it to be changed to a MH on the V5C as it's not a simple matter of chucking in a few bits and bobs, they have to be fixed in place and include a bed, sink, cooker etc as minimum I believe ... it's a while since I did my ambulance conversion so can't remember but when we bought it it had already been re-registered as a MH (don't know how as the 'conversion' was cr@p) so I didn't need to worry although everything in it was scrapped except the cooker!
Just another thought ... what's it's MOT status?
D
If it's still registered as an ambulance or any other emergency service vehicle it's exempt.
It's not possible to get an MOT until the DVLA change the registration class. The MOT online system that they use now won't allow it.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Mot has no interest in what any vehicle is registered as, Only its test class, decided by vehicle type and weight
If no record exists for any given vehicle, I can create a new one on site, for the purpose of the MoT only
May 16, 2014
817
1,063
Ammanford
Dethleffs Trend
since May 2014
Schedule 2, para 6 of The Vehicles Excise and Registration Act 1994 defines and ambulance as:
(a) constructed or adapted for, and used for no purpose other than, the carriage of sick, injured or disabled people to or from welfare centres or places where medical or dental treatment is given, and
(b) is readily identifiable as a vehicle used for the carriage of such people by being marked "Ambulance" on both sides.
Once any of the above ceases to be the case there is an offence under the Act of using a vehicle where a higher rate of duty applies
11,932
9,078
You will have to do it the old way and send the v5 in to DVLA
You then have a choice of insuring as a van or M/ caravan self build .....they usually allow 12 weeks to convert from van to M/C ....if it's going to take longer I would insure as a van until it's converted......AIB are great to deal with for conversion ins a d they know what they are on with unlike many ins co' doing this type ins
D
It’s not me and it’s not a motorhome conversion.
It’s a friend who has a work van that was previously owned by the fire service.
He’s been arguing with DVLA for about 3 years and has tried everything. For reasons best known to themselves the DVLA point blank refuse to change it. They won’t even acknowledge that there’s an issue.
chaser
Feb 16, 2013
19,734
52,021
uttoxeter
50 years
Not clear how you meen , is he useing it on the road or is it standing?
chaser
Feb 16, 2013
19,734
52,021
uttoxeter
50 years
Must stress my lad wants it right, and not useing it on the road till it's right, it is moted and insured though
11,932
9,078
Cannot understand his problem....I have re registered 4 ambulances (converted 3 sold one) by simply sending v5 in with change of use ....
The insurance is up to you be it ins as van or van converting to Motor Caravan ax explained above
D
It's registered and insured in his name and he's used it every day since he bought it.
He can't tax or MOT it because DVLA are absolutely adamant that it's exempt even though it's registered in his name. They refuse to change the class from whatever the exempt one is to PLG. They refuse to tell him why.
He's safe from ANPR and all the rest because it shows as exempt on all databases.
D
He knows what he's doing. He's involved in the industry.
He's sent the V5 in several times. They just send it back.
He's written to them.
He's phoned them.
They refuse to accept that there's an issue or that anything needs changing.
This has been going on for a long time.
11,932
9,078
All I can say is good for him :D no tax and if he has a bump no insurance unless he has informed ins (y)
Stretto Boy
1,503
306,565
Leicestershire
Since 2011
Contact @Yorick : as you can see from the “Dream of motorhome ownership ruined by DVLA” thread, he has his finger poised on the big red button!
