life in the slow lane
A quick question to the knowledgeable, are the 15 and 16 inch wheels interchangeable on the ducato/boxer model of 2001?
The way Fiat speedos over read it will probably make it more accurate.dont forget the extra size of the new wheels will make the speedometer read wrong
The PDC is different between the lightweight chassis and the Maxi. I know this as a fact.A quick question to the knowledgeable, are the 15 and 16 inch wheels interchangeable on the ducato/boxer model of 2001?
Surely if you get lower profile tyres to match, the circumference will be (roughly) the same and the speedo will be fine/just as bad.dont forget the extra size of the new wheels will make the speedometer read wrong
lower profile tyres with the correct weight rating? hens teeth I believe you will findSurely if you get lower profile tyres to match, the circumference will be (roughly) the same and the speedo will be fine/just as bad.
