Any one recommend a good sim portable router that gives 4g. I have a sim but quite often when in bad reception areas i can only get 3g for my fire stick.regards john.
Assuming you want WiFi off a decent 4G signal...?
A few options available. The Motorhome WiFi kit is good if you want that as you have the advantage of an aerial, a power block and a portable router/access point. This gives the best chance if getting and using a 4G signal. If its just portable use i.e. outdoors, then a couple of MiFi or portable units exist without the aerial so probably no better than what you already have.
A quick search on MHF for wifi will bring you loads of info...
