What Wattage Coffee Machine Can I Use In The Moho? (2 Viewers)
Mr Mousy
619
3,105
Llanelli
Hymer S840
First moho 11/2013, second 11/2014 current from 09/2019.
It is time to buy a pod type coffee machine to go into our new kitchen at home, I would like to buy one we can use in the moho as well.
Having had a look through old threads I can see lots of info on amps, watts etc but it makes no sense to me!
So my question is 'what wattage coffee machine can I use in the moho when not on hook up?'
Armed with the answer I will start my search for a Nespresso/Senso type machine.
We have 2 x 110 leisure batteries supplying a pure sine 1500w inverter.
We have a 100w solar panel.
An Efoy Comfort 140 system.
I guess the machine will only be used for two cups at any one time as Mrs Mousy doesn't drink coffee.
In anticipation of some suggestions.....thank you.
mjltigger
1,619
2,672
Trowbridge
Autotrail Dakota Max
Simple answer is don't use more than 1/2 your inverter as start up values can be twice normal running consumption.. bear in mind other items you are likely to run off the inverter at the same time..
Someone will no doubt tell you how long the solar will take to replace the power the machine uses in a minute
Apr 9, 2014
1,307
6,596
Lincs
We looked into this a little while ago, best pod machine we came up with was the Broken Link Removed, 1300 watt, neat, compact and often on special offer.
Till we get the inverter sorted sticking with the Aeropress, hand grinder and Aerolatte, I like fresh ground beans.
Oh yes, no idea how long your batteries would last but the eFoy has pretty much covered all the bases anyway I would have thought.
19,309
30,075
We use the Nespresso 1200 watts from memory, it's on 2Kw pure sine you should be fine on 1500watts and does'nt take much power as the heat cycles are very short, 5ah tops so should put it back in a couple of hours sun willing.
Steve
1,613
2,062
Compton Berkshire
on and off for 40 years
I can see you will have any problems you have some good kit, but as said just watch nothing else is on.
Steve
Gellyneck
9,199
18,146
More than toes wet now!
Just want to confirm you've covered all aspects. Has Mrs M signed off (in triplicate in front of witnesses) the purchase and use of said appliance?:whistle:
Judge Mental
Sep 2, 2009
6,650
5,883
Sarth London
Possl 636 FR panel van
1994 and beyond...
I wonder how Carthago do it as they offer a built in one with inverter but its priced @ 1200 euros :(
19,309
30,075
Dont know about the Euro price list but £ prices the inverter is £1260 for 1800 watts and the Nespresso machine is £230.
EDIT Euro prices Inverter 1800 watts 1465 Euro and Nespresso machine 270 Euro.
Prices taken from 2015 price list Chic models.
Judge Mental
Sep 2, 2009
6,650
5,883
Sarth London
1994 and beyond...
Ah OK! So its the inverter that costs the money...thanks:)
M
Madwife
We have a Nespresso machine and it only cost €70. It's the same as came originally with the mh and fits the space exactly. Never used it off hookup so can't help with owner used etc. it makes nice coffee!
Kath
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
On and off since 1983
Hi Martin, we were so impressed with our Nespesso coffee maker at home we have just duplicated it with the slimmer model for the MoHo, that way we just grab the capsules and away we go.
It pulls a maximum load of 1260 Watts and works fine on our 1700 watt PS Wave inverter
R
Robert Clark
Mrs C forgot to pack the capsules for our Nespresso machine and tbe compatible ones they sell in France taste like mud
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
Tried quite a few compatible ones and keep going back to "Nespresso".
Now that is worth knowing, someone posted on here how the ones in France can be purchased for a fraction of the price; well if they taste like Mud I'm not surprised.
Anyone else got input on this subject, as then I'll know to pack enough coffee for the entire trip.....cheers. .......... Griff
Armytwowheels
6,468
14,808
Market Harborough
Carthago S Plus - Iveco
Since 2011
Griff, take the originals for goodness sake. We tried just about every look-a-like brand we could find in Europe and nothing compared. Also the machine did not get on with a lot of the so called compatible pods.
Mr Mousy
Mr Mousy
619
3,105
Llanelli
Hymer S840
A further question for all you electricians...
Just bought a new Nespresso coffee machine it is 1260w.
The inverter (pure sine) is 1500w continuous and 3000w peak.
The inverter 'bleeps' when I make a cuppa.
Why and can I use the coffee machine without knackering either the inverter or the batteries?
Thanks Martin
19,309
30,075
Hi Martin
It might be worth looking at the battery voltage when the machine is working as the "bleep" could be low voltage alarm, check the voltage at the batteries and at the inverter terminals to check for excessive cable voltage drop.
Ours used to bring up the low voltage alarm until I shortened the supply cables to the inverter.
How thick and long are your cables?
I dont think you are going to do the Inverter any harm and the batteries depends on answers to above, what batteries do you have?
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Most likely a low battery warning. I would look at the battery voltage when the machine is started and near the end of its cycle. If you heavily discharge the batteries without promptly recharging them yes they will not last as long.
EDIT still typing while Martin was posting so yes we concur (y)
Mar 10, 2016
558
617
A Class RMB 750HE
Three years and counting, 30 years a tent tower.
Pack for entire trip, we've tried some of the others, even the M & S ones, and they are rubbish unfortunately. We actually have a locker known as the Nesspresso locker and SWMBO's biggest fear when mohoing is that this might become empty, especially the Caramelito section....:)We are hoping Amazon expands their drone delivery idea to cover nesspresso pod delivery to remote moho's as otherwise I cannot see us making 6 month trips without a Nesspresso trailer on the back.... I knew there was a reason we needed a 1.5T payload:LOL:
Techno
Jul 28, 2010
15,475
20,756
May 2010
My 1300watt kettle that takes 5 mins to boil 1 litre of water will pull my battery voltage down to 12.2 at start and 11.9 by finish. This recovers almost immediately to 12 .6 and climbs higher in only minutes from the solar input. I have a 500ah bank. If your batteries amount to much less then the voltage will dip much lower
icantremember
8,328
17,540
Near to Watton in Norfolk
Hymer T-SL668
since 2005
We use a Dolce-Gusto MiniMe (1500w) from our Waeco MSI1812 1800watt Pure sine Wave inverter which has a peak output of 3900w and has very little effect on battery voltage for the short time it runs.
For information of anyone interested, our inverter was fitted very tidily and professionally by VanBitz Link Removed .... @eddievanbitz (y)
19,309
30,075
Andy @Techno Mr Mousy has 2x110 ah battery bank, now as we all know some batteries are better than others, For a few years we were running on 2x80ah but on 5hr discharge rate so more like 110ah at 20 hr rate so I know that the Nespresso machine will run on this size bank, 3.5 minutes microwave then two Nespresso coffee pods would see our down to around 12.2 volts on load. Hopefully it is his cables.
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
I simply refuse to look at the gauges that way I remain blissfully unaware. Saying all that I'm currently parked close enough to @JockandRita and @Techno to plug in if I have problems.
I think jock might notice as he had an alarm fitted to his wallet which goes off if anything costs more than it should. :wink:
By the way, ,Jackie now buys the strong black coloured Lidll pods which are every bit as good as the Nespesso and a fraction of the price. NOT ALWAYS AVAILABLE SO BUY LOADS ONCE YOUVE TRIED THEM.
Griff
Oct 30, 2010
4,256
20,707
Suffolk or France or ........
A Class Carthago Chic
Since 2008
We have exactly the same set up but with 2x 90ah gel batteries.
I am reluctant to use it too often when we are not on hook up as I don't want to 'cream cracker' the batteries. I do get all sorts of warning bleeps when I turn the coffee maker on and the voltage drops. Perhaps I should just ignore them.
Am I being too cautious?
Richard.
R
Robert Clark
Richard.
If you're getting low voltage bleeps from the inverter control panel then I'd be careful
The Carthago control panel seems to alarm at a higher voltage, so I tend to ignore that
19,309
30,075
Richard.
Hi Richard we used to run ours on two 80ah without beeping so again I would ask how thick and how long are your 12v supply cables, we used our batteries for Microwave and coffee machine for three years before adding two more identical batteries to the mix, so now have two about 10 years old and two new ones, I know you shouldn't but I did anyway:LOL: and it all works great batteries show about 12.6 volts when they are working.
  • Back
