Terry Gill
Apology if this has been done to death before but what are member actual experiences of different makes of van tyres that emit the lowest road noise?
I was going to say most of that, I was in a hurryThe noise figure quoted for tyres is not what the average user wants to know. It is a measure of noise pollution, taken 7.5m from the centre of the vehicle traveling at 80kmh.
This often bears no resemblance to noise in the cab transmitted by the suspension & at different speeds. The same tyre will perform differently on different vehicles.
Anyone fitting new tyres will always say they are much quieter than the tyres they replaced, the old tyres will have hardened with age and will have far less tread on them so they will be noisier.
I can say the noise from my Toyo Observe Van tyres is more than acceptable in my van.
Me thinks thats a wind up.
Sure I read on here it’s 5 years, hope I’m wrong, thanks Les.I thought tyres should be ok at 5 years old, depending on wear & condition of course.
What age do they need/should to be changed if in good condition, I.E no sidewall cracking, and decent tread depth left? I thought it was 7/8 years?
LES
Thanks Les, I’m still in Thailand until the end of March, so I’ll have them checked over when I’m back, MOT April so they should tell me if ok or not.here you go Mickey1 .....1This is what Google had to say, I thought it was 7 years plus so you could be OK for a couple more years yet if your tyres are checked over.
LES
Quote:
What age should tyres be replaced?
There is no definitive tyre age limit as to when you should replace your tyres but once your tyres reach 7-10 years old, you should keep a close eye on their condition and consider replacing them. Tyre ageing is commonly identified by small cracks, known as crazing, which appear in the tyre sidewall.
Same tyre as DJA says the eBay one is 3 years old.Lenny HB , I’m going to be due new tyres (5 years old), what’s your opinion on these please?.
<Broken link removed>
or these.
Toyo Observe Van
Get Toyo Observe Van 121/120 R Tyres EAN: 4981910508427 online today for170.44 £ and compare with 44,344 other tyreswww.tyres.net
Depends on use, if the van is left sitting around unused for 2 or 3 months at a time best to change them at 5 years. If used regularly with a decent mileage put on them they will last a lot longer as use keeps the compound supple. Standing around particularly with a load on them the compound will harden and be more liable to cracking.I thought tyres should be ok at 5 years old, depending on wear & condition of course.
LES
