What Tv bracket (1 Viewer)
sean
73
4
Torquay
fiat ducato Carioca 635
Looking for s tv bracket for our new mh it's our first one it's a 2007 fiat ducato Carioca 635 any help and pictures would be good thanks
sean
sean
73
4
Torquay
Hi techno100 this is it the cubord its 400x400x400 hope this helps I'm looking at a 19 inch to fit in there on a slight angle thanks
43,323
49,414
Too many variables to answer.
How big/heavy is the intended tv
where in the motorhome is it being fixed
does it have to swivel or will it be fixed in one position.
43,323
49,414
Something like this would do the job but any bracket is going to have to be screwed to the cupboard side wall.
the vans outer wall is not strong enough to carry that much weight on a few screws.
sean
sean
73
4
Torquay
I need it to fit in this cubord if I can slide in and out and drop down maybe maybe double arm one but would like it to sit abit lower so you don't get neck ache
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
I don't think you can get 19" TV into a 400 cupboard.
My 19" TV is on one of these
43,323
49,414
My first van was a crapioca.
Tv cupboard was above the dinette and that was the only seating so watching tv was literally a pain in the neck.
I abandoned the tv position and used the cupboard for other things and the tv was simply stood on the kitchen worktop and strapped flat to a seat cushion when travelling.
43,323
49,414
400mm is approx 16 inchs.
A 19 inch may fit at 45 degrees but will still stick out too far to close the roller shutter door when travelling.
sean
sean
73
4
Torquay
Ok thanks I was hoping to fit it in there at an angle with the right tv bracket
32,645
66,521
Instead of putting it in the cupboard why not mount it on a bracket underneath? You could mount it either on the bulkhead between the seats on a removable bracket (1st photo) then if the seats are used for travelling then the bracket and TV could be removed and stored elsewhere in transit, or under the base of the cupboard itself with a bracket which folds down (2nd photo).
