- Aug 16, 2021
- 31
- 44
- Adria sunliving lido
Dear MH experts,
I have just this morning taken delivery of a second Exide 85Ahr GEL battery to be installed in parallel with the 5-6 yr old original in our Adria sunliving with a ELB206. We spend most time away from EHU. We recently installed 2 x 120W solar panels (Voc 21.5 and 22.5; Imp=6.67A Vmax=18V) and while we thought about the morass of information about charge controllers, I installed a cheap (£11) controller as a temporary measure about 2 weeks ago. At the weekend I noticed our 500w inverter (used for charging phones and running some music) wasn't working so checked the connections and found that the battery was showing 17v across the terminals - exactly the same as the solar panels, so the (very hot) charge controller had obviously blown and somehow connected the battery direct to the panels. I immediately disconnected the panels and the battery showed 13.9v and appears to be working OK since. (Do you think we dodged a bullet here?)
The questions is now, what charge controller do we replace the faulty one with? I have come down to three choices (though there are many others). In no particular order, there is 1. the Votronic Duo 250 marine (main advantage is that it will trickle charge the starter battery through the EBL but needs additional battery temp sensor and MT-50 to monitor), 2. The Epever MPPT 20A kit (comes with all cables temp sensor and the MT-50 monitor also appears to be more substantial and to have better heat dissipation?); 3 Victron 100/20 (has bluetooth connection in built but needs temp sensor.) The difference in cost is not a big consideration.
Any comments would be really appreciated. Thanks.
