Urs4_2008
The panel has higher voltage. P=UxI. P=30.8v x 8.28 a = 255 watts. So it's fine regarding this.No Problem! Maximum output for panel is just over 8 Amps which is poor for 200W and you will never achieve all of that anyway,
Hi PhilipNo Problem! Maximum output for panel is just over 8 Amps which is poor for 200W and you will never achieve all of that anyway,
Thanks, Andy63 I've done a lot of testing myself, along with several installations. I've testet a lot of different charge controllers. In smaller installations there are little to no difference (<200w). From 400w and upwards, the amperage rises to a point where it matters - specially regarding heat. 400 watts can generate ~25 amps. If you use a PWM instead of a MPPT controller, you can observe in a 400 watt solution upwards of 34 amps. Normal household wires and breakers are 10 amps and 16 amps.I see we are back on the series parallel debate again...
A good while back when andy @Techno was contributing to these sort of threads i remember him doing an actual test ... it did seem to suggest that there was no gain in the series connection for your average mh install and id anything more to be gained with a parallel connection...
https://www.motorhomefun.co.uk/foru...lator-parallel-or-series.106170/#post-1380718
Have a read @Urs4_2008 .. theres always more than one way to skin a cat.... both work... depends on the circumstances.
Andy.
Funflair is correctHi Philip
I guess there is confusion as the panel spec is just for panel as in the panel output not the output you would expect to see from the controller when it converts 30v to 12v the amps has to go up following the rules of V=IR.
Martin
It’s a bit like the magic circle, it’s called the 12v circle and they are sworn to secrecy so as to keep us normal people in the dark so we can not do anything. Haha
