What is the one tool or spare part you always carry?
Renault Trafic
After building our own campervan, we quickly learned that something which feels perfectly solid on the driveway can behave quite differently after a few hundred miles.
We now carry a small collection of tools and spare parts, although it is slowly becoming less of a toolkit and more of a mobile workshop.
What is the one tool, spare part or bit of repair kit you would never travel without?
Credit card. You can carry all the tools and all the spares, but its the one item you haven't got that will go wrong or fail.
The problem is, you now also need a signal.
Remember the good old days when one could just put it in a gadget, they would slide the handle back and forwards, and you were on your way! 🤔
Corkscrew!!
ODB2 Scanner. It's so handy to figure out why your motorhome won't start. My MH is a year old, and away in France I used it as my MH wouldn't start after starting it 5 minutes earlier to drive to the MH drainage spot on the campsite. After that the engine wouldn't turn on. Turned out the immobilizer key fob had gone to sleep for some unknown reason. The scanner told me the immobilizer had prevented engine start. A quick call to the tracker company and they explained how to get the fob out of sleep mode :rolleyes:
Laptop with mes and obd
Oscilloscope+meter
Box of spares. Plumbing connectors, pipes, electrical connectors, cupboard latches, heater gaskets, temperature sensors, pump, glow pin, fan motor, controller, fuses, every type of connector used in build, screws, any special fixings, gaffa tape
Oil, oil sump plug and washer.
Torque wrench and wheel socket.
Most necessary tools, maybe!
Fluke multimeter with DC clamp on for sure, would not be without it.
I always carry the part that I never need 😂😂, a few reports on Knaus page about the pump giving up after about 3 years so bought a spare when our van reached 4 years old and it’s still in box 😂😂
I think spares that are specific to your van and that would stop you from using it, most other things are probably generic to MHs and readily available.
Many reverted to that system when the power outage occurred in march last year
Uni-t clamp meter, 12v soldering iron
Selection of spares, ducato, MAP, Differential DPF sensor, Brake sensor, turbo solenoid.
Selection of tools and spares inc sureflo pump and self amalgamating tape.
I have also recently aquired (for the toad) a a combined battery booster and air compressor
Ps great minds (have same items on thier lists)
Multimeter and obd reader. Actually carry loads. Spare fuses instead multiple types my van has. The only real spare I carry is a water pump also a spare cassette currently in use as the rubber doubry on the first is leaking and I don't have a spare for that.
Bloody hell
Spare water pump and now a spare water pump motor
Clamp multimeter
Noco 70GB booster
Spare cassette
OBD-II reader
Electric screw driver
1/4” socket set
1/4” drive screw driver set
6-22mm ring spanner set
Ring 900 air pump
4 x inner tubes and 2 x green gunge for electric bikes
1 x spare firestick lol
100’s of tie wraps
2 x gaffa tape
Loads of screws
6 x silicon spray aerosols
1 x spare wheel and tyre (brand new)
Wheel nut extendable wrench
Torque wrench
USB charged bike pump
OBD powered HUD
Loads more and a partridge in a pear tree 😉👍🤣
BTW if anyone is stuck for a Sureflow water pump motor, it’s brand new, it’s a tenner or 2 pints lol
