I’ve now assembled all the kit to convert my James Cook Sprinter to Lithium ( Sterling Lifepo4 on sale at moment ). I’d like some views please on what max input current draw to set the Votronic BtB at. The set up will be my 200ah alternator, 50A max output on the Votronic BtB, 2x 100ah Sterling Lifepo4. 25mm cable except for a short stretch of 10mm between existing disabled in/out terminals of the existing split charge relay( so as to get cable into Votronic ) , 100a fuse output from there and either a 60 or 80A fuse on input from 100ah Starter battery. No EBL or anything- power at moment goes straight from the split charge relay to the batteries.
The Votronic blurb doesn’t say what the max current draw in is but there is a switch to limit to 68A max. So I’m pondering whether to leave it at max or limit it to 68A? Presumably limiting it will have a corresponding effect on output? Also presumably either way it should be an 80A fuse rather than the 60A! Awkward to get at the Votronic so want to get settings right first time. Thanks
