- Sep 25, 2009
- 922
- 1,683
- coachbuilt
- since 2004. Tugger 10 years on and off
New bump stops coming today. So as soon as weather dries up it will be my next job.Old ones loosened easily. So should be a quick job.
Fire Maple Antarcti Stainless Steel Kettle 1.0 Liter Camp Kettle | for Boiling Water, Tea, Coffee, Freeze-dried Backpacking Meals | Portable for Camping Bushcraft and Travel £28.95
AMZCHEF Single Induction Hob, Portable Induction Hob with Slim Design of 4.45cm, 20 Power Levels and 20 Temperature Settings, Fashionable Black Glass Panel, Touch Sensor, Hour Timer, Safety Lock £36.49 Thetford pump, over £50Not fixed yet, but removed and ordered replacement.
Thetford pump for the cassette flush.
Complete bugger to remove!
What a pain - but congratulations!After last years MOT and the inspector insisting that it failed due to headlight high adjustment scrolling wheel not operating correctly (the inspector ended up telling me to remove the switch and put tape over the holebefore he passed it) I’ve been trying to fault find why they had stopped working.
Lots of head scratching, never had an issue on an MOT prior to that one etc, I set about looking for the gremlin. So, headlights out, laid flat on the bumper and the fun began. Lots of false reading on my multimeter, various contrasting voltage outputs and stripping of the switch and checking circuits, which wasn’t easy, as it required SWMBO to sit in the cab rotating the switch etc.
So after an entire day playing catchup with it, I retired for the night, with plenty of thoughts running through my mind. I ordered a new switch, from Slovakia as you can’t get one in the UK at the moment, they’re all out of stock. It needed replacing as the brittle plastic had cracked inside the assembly.
Following morning, I tackled the dash wiring, to try and establish why I was getting such curious voltage readings and, after running a neg earth directly from the battery and spliced it into the tight wiring that led up to the switch, I got a result. So I made a new earth cable, run it a short distance to the metal frame that supports the dash and the lights lower and raise successfully, winner
Then, it was me dismantling one of the headlights, as we had a large and sudden downpour and water got into the headlight and splashed over the inside of the lenses. That’s now been dried as best I could with micro fibre clothes pushed through the holes meant for the bulbs, and is in the airing cupboard hopefully drying out the remaining moisture.
Because I was behind the dash, I removed all the air outlets and gave then a good scrubbing to remove the spiders, flys and debris that had accumulated in there. Wipers also came off and washed with a scrubbing brush and again, was surprisingly grubby along the rubbers.
Now I just need it to stop raining and pop it all back together again. I can do the inside no problem, but will need to be careful not to get more rain inside the headlight.
MOT is booked for Wednesday morning. As I have some pretty sick and frail family and need to travel down to Bedfordshire and then London, the chap said no problem, I’ll book it in for……
0530am![]()
The offending little bugger
Someone else needed one and couldn't be bothered to ebay it!Not fixed yet but we lost the water filler cap. It was there when we left home and when we left the motocross meeting so as no idea how or when.![]()
It was at a motocross meeting…can be a few dodgy sorts there at times.Someone else needed one and couldn't be bothered to ebay it!
They arent stealing water caps.It was at a motocross meeting…can be a few dodgy sorts there at times.![]()
So true Phil…..sadly.They arent stealing water caps.
We had to fit a locking cap after having one stolenThey arent stealing water caps.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
