What have you fixed on your motorhome this week?
I have had my 3500kg MURVI Morello, since 2017 and the Shurflo water pump situated behind the back of the wardrobe, near all the electrics, has always bugged me.
#1 because when draining down for winter, it's a pain to get to and
#2 being next to all the important electrics, if it sprang a leak and sprayed the pressurised water all over the place, it might have serious consequences.
So, last year I moved the pump to behind the rear doors on my PVC where it's much more accessible and safer.
HOWEVER, the little inline filter on the inlet side of the pump has always, to me, seemed the wrong way up because, the clear plastic cover over the filter, is beneath the water pipe and cannot drain completely.
The remaining water can freeze, expand and crack the plastic causing problems next Spring.
Now I have secured it, on TOP of the pipe and now should drain completely!
🤞For next winter!
An update, today in the 🌞 15C, I took everything out of the wardrobe, removed the back, so that, before I poodle off to the Norfolk coast next week for a fortnight, I could double check all the pipework of the water system as we have had a few sharp frost for the past week. -3C and check out the inverted inlet water filter.
The filter on top of the pipe is good. 👍
The water system pipework, also appeared good initially but then I noticed a damp spot on the floor.
On closer inspection, one of the 2007 original connectors was leaking slightly from a metal compression joint.
I decided to replace this joint with a 15mm Speedfit joint instead of the 12mm metal one. (Slowly endeavouring to replace ALL 12mm eventually) boxed it up and tested👍 except the old one next too it started leaking also where it had been disturbed, and was replaced. (All the old plastic pipework is becoming hard and rigid.)
Pressure up, and all was good!
By this time, my poor old knees where screaming ENOUGH!
Lunch was beckoning, I will tidy it all back in place tomorrow! 😄
Now off to enjoy lunch in the sun! 👍
Absolutely nothing ...Still thinking opened bonnet today looked under van
Closed bonnet made tea
Back to work.now , tomorrow is another day
Brilliant job, well done sir.
Can you share how you made that please ?
I take it you just replaced the glazing ?
The old double glazed are 2.5mm.
It’s too difficult to make new double glazed and Ecco quoted £650 inc shipping.
So I measured the window, calculated the corner radius and had the Perspex cut. 5mm tinted.
Then I removed the top metal hinge from the old window.
Used a Dremmel multi-tool with mini cutting disc to create a groove/channel for the metal hinge strip.
Slid on hinge strip.
Cut holes for catches and struts
Fit window
Being 5mm thick, they don’t get much more condensation than the old units.
Total cost was £90 for this one and £80 each for the side windows.
As I said, I could not justify over £2,000 for three windows on a 25 year old Motorhome.
Spent the day on my knees wiring up two Lithium batteries 630 amps to power my inverter,
My knees have seen better days so can only manage four hours before I have to give them a rest,
As they say youth is wasted on the young 😭
Fit window
Well done you 👍
replaced faulty Auto Switchover unit.
Removed the FW tank filler from side of the van, stripped off all the old mastic and replaced it with fresh mastic. It had been leaking after rain.
STARTER MOTOR
jacked up for bolts back on under 30 minutes
It was.sooooo easy
Takes me an hour to decide if I am going to do the job, then another hour or so on the Internet to work out how to do it, plus diversions looking at plane crashes etc. Another hour gathering tools, quarter of an hour jacking up. Ten minutes to get old one off, fifteen minutes to get new one on ( why does that always take longer). Another hour testing, getting it off jacks and tools away, or just left lying around in the conservatory. Accept bollocking and put tools in shed.
Simples.
Replaced the four exhaust rubbers on my Peugeot Boxer as they came up as an advisory on the MOT. They looked old but no sign of any perishing and they were very tough.
Anyway, the job is done. I like to get all the advisories ticked off before they become an issue.
Got stuck on wet grass recently and had to be pushed off. The cab was close to a fence, so couldn’t use the front towing eye.
Decided I needed a rear towing point, so made a bracket that fitted to two existing holes on the AL-KO chassis
A bit of welding on the step
Plated both sides I cut out more than was needed but of a job laying under it over head welding underneath full weld none of this plug tack welding malarkey
Wb
How’s the new van coming along Bill…🤔
Doing bit to the red van at the moment faled on sum welding
But I have the kit to do it
Been on it a few days
There was two bits that need a lot of attention cut out more than needed so I could treat it both sides
Made the Panils in my workshop
WB
Haven’t actually even looked at it there’s a bit of welding to do and wax oil it but don’t know till I have had a look
Last two day is the only time I have been out in two weeks after getting out of hospital
WB
I can never make up my mind about using wax oil after doing some weld repairs on vehicles.
Half of my tired brain says spray as much as you can inside box sections to stop any further rust.
The other half is afraid of setting fire to the waxoil should it need another repair in the future.
Now halfway through fabricating and making up panels to repair the RH chassis outrigger for the forward jack point etc. Luckily only a small hole on the LH side so just a simple patch.
Being an A Class having to be careful not to set light to the plastic panels under the fibreglass front section.
Just keep a garden hose primed and the wife fire watching
EDIT
Another thing I use is my pressure whaser with the detergent fome attachment and whash in up fairy liquid in it it makes a fantastic fire fitting fome never had to use it but did test it
Rally thick foam
I did have my garden pump up garden sprayer and hose ready. Never thought of that washing up liquid foam idea, better than keeping a bucket of bulls blood handy.
