What gas BBQ? (1 Viewer)
Apr 30, 2017
203
105
Blisland Cornwall
Bailey Autograph 752
Owners since 2017
Hi All
We are off to France again in June and we would like to take a compact BBQ with us this time. We have a Bailey 75-2 with an external gas point all ready to go but no Barbie!
Can anyone recommend a small-ish gas barbecue? A friend has the small Cadac one but we are looking for something just a bit bigger but not full sized.
Bertie Bus
Apr 30, 2017
203
105
Blisland Cornwall
Owners since 2017
HI Both
Thanks for the prompt reply.
Do you know what model it is? Our external locker is a bit on the low side but as with most, we could access it from under the bed.
4,256
20,707
Suffolk or France or ........
A Class Carthago Chic
Since 2008
Just bought one of these Cadac's today.
It seems great for two but might be the small one your friend has.
Bertie Bus
Apr 30, 2017
203
105
Blisland Cornwall
Owners since 2017
Ooh I like the look of that. I will have a look around for the best price.
Bertie Bus
Apr 30, 2017
203
105
Blisland Cornwall
Owners since 2017
Hi All
Just had a dim moment. Do I need a regulator if I am running the BBQ off of the fixed van outlet?
Chris
21,042
277,714
None
10 years
Hi Chris
We have one of those from our camping days. I see what you mean though with a hot plate on top.
I think you need to be a bit careful with the size of the hot plate. I believe these cookers are banned in Australia because they can explode. I think ( but don’t know) that problems arise if you get the little gas canister too hot by covering it with a pan or hot plate.
We have used one for 8 plus years without any issue though.
4,256
20,707
Since 2008
Hi All
No!
The regulator is by your gas bottles/tank and is low pressure throughout the van, including the BBQ outlet.
Richard.
Bertie Bus
Apr 30, 2017
203
105
Blisland Cornwall
Owners since 2017
Hi Richard/Wanderingyp
I thought that was the case but I thought I had better check. Better safe than sorry.
The Lotus grill is one the wife has seen and likes the look of, decisions decisions.
489
689
Surrey
Coach built
4th year
Hi All
No you need a external bbq point male plug, most dealers sell them.
We have a cadac which is brilliant just as good as our home bbq, had the small cadac safari to start with in our pvc, but got fed up with the legs collapsing on me & small cooking area, so upgraded to the grill chef which is so much better.
1,547
1,264
West Sussex
Carthago Chic A clas
Since 1990
We use a Cadac Safari Chef 2 LP. Compact design (legs retract) doesn't take up much space. Easy to clean. The LP model works direct from the BBQ point. Can even cook pizzas if you purchase the stone plate.....I understand.
1,042
997
Cumbria
Pilote P740FC
We had a Cadac (Carri chef) for years and changed it last year for a Weber Q1200. We’d certainly not go back - far more like a real barbecue, and easy to set up and use. The Cadac is more an outdoor cooker, but does have loads of attachments available. The height of the domed lid on the Weber may be an issue, though as Sueandjohn say.
11,722
13,698
Since 2013
My vote goes to the Weber Q1200. Cook the meat low and slow with the lid down so no flare ups to burn the meat. Very versatile as it can be used as an oven as well as a grill. We have used it to roast meat and vegetables, bake jacket potatoes, and cook frozen chips. Add a cast iron griddle and you can do a full English breckie on it..
I have the larger Q2000 at home. It does the same and also makes a good pizza using a pizza stone. But that is too large for the Q1200.
3,413
11,346
South Ayrshire
Globecar Campscout
Since 2018
We have bought one of these too. Going to try it this weekend.
As we don’t have a BBQ point we bought the double adapter so we can run it off 2 smallish canisters. Also a regulator to run off 6kg propane.
mfw
Banned
Sep 16, 2017
1,224
508
Worthing
Minxy
32,623
66,459
E Yorks
Carthago Compactline
We've had various types and found that this is the best for us, easy to use and has a warming shelf for stuff that you've already cooked:
Bertie Bus
Apr 30, 2017
203
105
Blisland Cornwall
Owners since 2017
:sun:Thanks all for your input. We have finally decided on the Cadac 2 cook 2 pro as there is only the two of us and the wife says I would cook too much on a bigger BBQ (ergo I have to eat it). It will fit nicely in the outside locker and I have purchased a 2M gas hose to keep it well away from the van when cooking.
Have fun in the sun
