Whalewater master (1 Viewer)
May 28, 2021
105
220
Essex
Autosleeper
We are away on our first trip in our motorhome and have problems filling up with water.we have a whalemaster system with a small inlet hole under flap.we plugged in the hose and attached it to tap to fill up. Waited ages , checked water gauge and showed less than 25% full. Tried again, same. Warning light came on saying low water. So it looked like water had been going into but it hadn't. I've looked on you tube and it looks like this system is to leave connected but we just want to fill up tank then go to pitch. Can anyone help please? Also how can we add puriclean when we have this stupid system. Tank is sealed from inside so no way to put in additives. Can whale system be removed easily so we can use normal hose?
Feb 18, 2017
4,130
8,004
Greenwich, London, UK
Hymer MLT 570
What is the vehicle ?
Most have drains, which means the water the water will have been coming out as as fast as you put it in
C
May 28, 2021
105
220
Essex
Autosleeper
Autosleeper Broadway. Didn't see water coming out anywhere .We have a drainpoint but nothing came out.
Dec 2, 2019
4,064
9,082
South Lincolnshire
Rapido 7065+
Broken most bits now
The spec says you need a 'plug adapter' to make it work as a hosepipe. Yours looks more like the Truma adapter rather than a hose adapter although I've only ever used the pump in barrel setup so don't really know what I'm talking about again :unsure:
Aug 21, 2008
693
1,357
Lincolnshire, UK
Autosleeper Symbol
Van Conversion
If like ours you have to have your 12volt switch above the door switched on to activate the water supply
C
May 28, 2021
105
220
Essex
Autosleeper
I think you are right Alan. We turned on the electric and water went in up to 50% hurrah. We have had whole weekend without water.Didn't say that in instructions.
now how to get puriclean into tank as tank under seat is sealed .?
