Whale water pump inlet (1 Viewer)
Murphy
92
53
Mansfield
Shire Conversion
hi all,
I am thinking of fitting a whale water pump inlet to my 2007 Autoquest 130 and then having the pump sat in the water but all the time to up fill the on board water tank,
Question is these come in either micro switch or pressurised ?
Which was is required ?
Anyone else done similar ?
Cheers
11,951
16,556
I have but the socket is permanently powered so that once the container is empty I simply unplug the pump. A mod for the future (that I've done before) is to use the drop in pump supply current once there's nothing to pump to switch it off. That way I can press a button indoors to turn it on then forget about it.
Murphy
Murphy
92
53
Mansfield
Shire Conversion
Thanks Tony,
Did you utilise the micros witch model ?
Jan 28, 2008
10,111
18,365
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
if your just filling from a container its the microswitch type only runs while its poweredyou would never get pressure build up to work the pressure switch type as you will have an open end into the tank
Sep 16, 2010
3,010
2,858
Bungay Suffolk
Autotrail TrackerEKS
Sorry just re-read the OP.. I just followed Tonyidle and rather than unplugging, I just switch it off when container I am de-canting from is empty..:oops:
mjltigger
1,619
2,672
Trowbridge
Autotrail Dakota Max
My old caravan had a pressure switch. Turn the tap on and water starts to dribble, enough to trigger the switch and the pump comes on. It was the only pump it had common with many caravans. My camper has an in board with a submersible and a microswitch. the only thing with the pressure switch is it doesn't stop when the water runs out.. but then nor would a microswitch. I think if you are using it to pump water out of a container to fill an in board your best bet is to switch it on and off by hand.
