Whale water heater goes <backfire> (1 Viewer)
Jane And Rog
1,091
6,516
Ashford, Kent
Adria Twin 640 SGX
Recently, since 2017
Our three year old whale water heater is trying to start but not firing successfully. It does the usual pump-pump-pump-ignite but then sounds like it backfires. It does this three or so times then switches itself off and lights the red “I’m unhappy” led solid. Our gas and water are good.
Any ideas for how I can fix this? In France at Poitiers now, likely to be in Spain tomorrow or the day after.
Jane And Rog
Jane And Rog
1,091
6,516
Ashford, Kent
Adria Twin 640 SGX
No luck. :( Ours is an external under slung heater and has a single exhaust that is solid and dry and well connected. However it definitely sounds like some gas is exploding in the exhaust and I am getting single flash error codes that indicate it’s not getting a flame.
I’m at a bit of a loss - the only controls I have for the heater are the single switch and the drain valve :-(
94
71
Lymm, UK
Rollerteam Toleno r
Since Oct 2014
Our whale on previous Elddis was like a balanced flue boiler ..inner and outer tube\flue. it was forever failing but badly fitted.Sorted it , Rollerteam we have now better built. same two flues though. Check inner tube hasn,t contracted .I think inner was gas out and outer was air in.
120
432
West Yorkshire, UK
Hymer car
25 years
Hi mine is also underslung and the exhaust has an inner tube that takes the gasses out and an outer that draws combustion air in.
If the inner disconnects you will get the problem you describe.
If you pull the outer tube off you will be able to see.
Chas
94
71
Lymm, UK
Rollerteam Toleno r
Since Oct 2014
Chas
If i remember the inner tube is the silver heat resistent convoluted tube the outer is black convoluted tube both just push fit on to the bracket. I had to really fix the silver one to the bracket as there was no slack before pulling on the outer tube .any kinks in tube will cause probs.
Jane And Rog
Jane And Rog
1,091
6,516
Ashford, Kent
Adria Twin 640 SGX
We have changed to Gaslow fairly recently but we’ve used the water heater several times since then.
I’ve also now understood the inner/outer tube and had a look. The inner is securely fitted as is the outer. We tried an Adria dealer today but they’re all still closed for new year. We’ll try one more before I go to the length of removing all of the exhaust tube and checking it’s ok.
Jane And Rog
Jane And Rog
1,091
6,516
Ashford, Kent
Adria Twin 640 SGX
Thanks to everyone who suggested fixes. We’re in Morocco now (see Jane’s thread for a blow by blow account) and my preferred fix is “relax and be happy grubby.”
Once we’re in the south and it’s hot I might disassemble the exhaust and inhaust to see if there’s a kink.
Jane And Rog
Jane And Rog
1,091
6,516
Ashford, Kent
Adria Twin 640 SGX
