Whale expanse under floor water heater
Soots
Peterborough, UK
Elddis CV20 Impressa
Since 2020
Hi, I have an Eldiss CV20 2020 model with a dripping drain valve! Has anyone else had problems with one?
It's been repaired two weeks ago,
but is still incontinent!
Going back again tomorrow 🤞
Regards Soots.
Solution2
Ours kept dripping having closed off the valve from being left open over winter last year.
I cured it by heating up the water in our Whale water heater and then gently opened the valve a bit to let hot water run over the seal for 30 seconds or so.
The heat softened up the seal and it has been fine since.
limescale/grit or slight crack in the drain valve. Some workshops think a quick flush is sufficient, but if the issue persists, it needs a new valve
I thought they put a new valve on when I was a fortnight ago?
I'm getting it looked at again.
This time I'll check it before I leave!
Thanks for the reply Big1.
Solution
Thanks I opened and closed it when upto temperature to blow any obstruction out, to no avail.
But I'll try that now. 👍
Hi tried it twice! No go I'm afraid,
But thanks, if it had worked it would have save me a round trip of a100 miles! 👍
Have been to Daventry,
It's a pressure release, it's supposed to do it! Grrrr 🤣
