On our Burstner MH there is a sliding table mechanism...
The slide is controlled in either direction by a large screw handle that threads into a boss that is secured to the table mount.
One of these bosses must have come adrift in the past and has been repaired by firstly a crude attempt to arc weld and then by an epoxy type material "glueing " it on but this has come adrift also.
I have cleaned away all the epoxy resin and the weld spots to find that the boss is let into the steel channel by a slightly smaller diameter being turned on it to form a shoulder that locates into the hole pre-formed in the channel.
What I am seeking advice on is the best way of securing the boss back on to the channel. It looks like the arc weld has been quite heavy handed and eroded a small section of the boss so I am presuming that welding isn't the solution. Is there a "best" steel to steel epoxy resin type of adhesive that would secure the boss in place?
Of course it has to be added that overtightening of the screw handle will probably have the effect of pressing the boss back out of the channel so we will have to learn to be a little lighter handed whilst securing the table.
Thanks.
Thanks.
